  • June 23, 2025, 06:02:41 AM
Author Topic: Great Luck with the FSR, Now Moving on to the OS Max 46 SF  (Read 2478 times)
Offline Gary Anderson
« on: April 26, 2011, 12:20:49 AM »
Hi guys,
Mr. Bill was asking if the older OS Pipe Type engines was worth giving a try to see if running pipe would be the answer for some that didn't want to spend a million dollars. I can really say that my OS Max 40 FSR/ABC on Pipe is great. I have a few of the OS Max 46 SF/ABC engines that I purchased back in the eighties. Not knowing better I ran them using a muffler and had great success. I would run my ST 60 for a while than switch to the OS 46 SF/ABC and couldn't really tell which one had more power?? Now that I have a pipe set up that I purchased off of e-bay, cheap, I can give the OS 46 SF/ABC a try on pipe. The 46 has two sets of holes for muffler or pipe, found out that the inter set will accept the FSR Header. The bolt pattern is the same on the 40 and the 46 but the 46 is a little wider, has a bigger head but seems like the prop will end up at the same location. I'm going to start with a 12/5 prop and I believe that will be close. I'm going to use the same pipe distance and change from there. The 46 weighs a little more but I believe it will make a lot more power. The only way I know to test the power is bye using a fish scale to see how much she will pull. I don't remember how much my OS 40 FSR was pulling, so I'll have to hook her up and check one against the other. I was looking to buy one of the OS 46 VF but I believe I'll have a better set up with what I have. The worst part will be is that I'll have to make my own header if I want to Tailor the pipe inside the fuse. Could set up a degree on the engine and do it that way but the plane is already build??? I'm really having fun playing with the different engine and finding that they work just great and ya don't have to spend the million bucks to have fun. Let ya know how it turns out, Gary
Gary Anderson
Offline afml
Re: Great Luck with the FSR, Now Moving on to the OS Max 46 SF
« Reply #1 on: April 26, 2011, 05:10:04 AM »
Jim Lee has good results with his OS FS 46. Might check with him also. Interesting reading in the Impact article in the May 1991 issue of Flying Models. Paul Walker goes into detail about different acceptable power options using various OS motors.
"Tight Lines!" H^^
Wes
Wes Eakin
Offline Andrew Tinsley
« Reply #2 on: April 27, 2011, 05:43:09 AM »
Hello Gary,
  I am not sure if hooking up the planes to a spring balance will give you a measure of how much power the engines are putting out. I have always thought that if the engine is stationary then the prop is stalled. Not sure you will get the right answers going this route. Need an aerodynamacist to chime in here!
Andrew.
BMFA Number 64862
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: April 27, 2011, 09:15:28 AM »
Before you get too far into the process you may want to remove the back plate and check the aft end of the crankshaft. If it has an "S" stamped on it, it is a stunt crankshaft. The engine will like to run bigger props (12x5) at lower RPM (in the 9000s). If no "S" it is an R/C crankshaft and will run more like your FSR. Rest of the story: I just went through this with my SF 46. It had an R/C crankshaft, I changed it to a stunt crankshaft because I like that type of run better.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #4 on: April 27, 2011, 10:14:58 AM »
Hi guys,
Thanks for the information. I bought the OS Max 46 SF new as a C/L Stunt engine from Tower in the eighties. I'm not sure that using the fish scale will give me the power that the engine is putting out but I can compare each engine by using this method. I believe the stock venturie is around .310, as I remember the engine came with two venturie's and a few extra head gaskets. I ran her yesterday and did well but I want to make a few changes. I had the old stock needle valve set up in her, its has to many chances for air leaks, so I've changed it to one of Randy's set up's. I need to install a new glow plug, the one recommended by Randy. I believe the pipe length I was using is to long (21"). I'm going to change it to 18.75. She wanted to run around 11,200 the same as the OS 40 FSR, she seems to have more power than the 40 FSR. I'm going to go burn a few circles with the FSR today so won't get a chance to play with the 46 SF until tomorrow.
Thanks for your input.
Gary
Gary Anderson
« Reply #5 on: June 06, 2011, 09:43:11 AM »
Hi guys,
Finally got the engine, pipe system and the whole works installed on a test bed plane. (The OS Max 46 SF) The only tank I have available is a 12 ounce tank, to cheap to put out five bucks for a new tank, could make one for less?? What the hick up it'll be fun flying for thirty minutes, Ha Ha. Start in the morning and finish bye night fall?? I'll short tank her!! I'm using a 12/4 prop as suggested bye Randy, pipe length 17.75. The test bed is a sixty size plane in the neighborhood of 66 to 70 ounces. If the weather is good tomorrow I'm going to burn a few circles with her. I believe the motor runs as well as the OS Max 40 FSR if not better. She seems to have more power. Let ya know how she does tomorrow. (Just having a lot of fun with piped set ups.)
Gary
Gary Anderson
« Reply #6 on: June 06, 2011, 02:17:19 PM »
Seems like the OS 46 AX (ABL) isn't widely known for stunt.  This is an R/C ball bearing engine that Tower sells for $140.  Weight is quoted at 13.2 oz without muffler (but with R/C carb).  I converted mine with a stunt venturi and I'm impressed with its power and steady performance.
« Reply #7 on: June 06, 2011, 03:40:18 PM »
It won't, for anything except for exactly similar props -- then as soon as you need to change props to properly load the engine, your measurements go out the window.
Only if the prop has a very high pitch to diameter ratio.  Something like a 12-5 isn't going to be stalled over most of its working area.  I can't remember the exact figures (and it depends on the blade shape), but if I remember the rule of thumb from old-style (NiCd and brushed motor) electric flying it is that you worry about the prop being stalled on takeoff at P/D ratios of 0.75 and higher.
« Reply #8 on: June 06, 2011, 10:30:25 PM »
    That will tell you the static thrust, but that doesn't mean very much to in-flight performance and certainly won't tell you much about the power.
« Reply #9 on: June 07, 2011, 12:26:01 AM »
Hi Brett.
I was just trying to see the different in pull between the two engines. Not sure it would be a fair test, cause using a bigger prop on the 46 would give it an advantage?? I would think the 46 would be a stronger engine?? The OS 40 FSR is a very strong engine and not sure the OS 46 SF is designed to have the same power as the FSR?? I believe you're correct, it would give ya the power output, everything seems to change once the plane is in the air?? The 12/4 prop I have isn't any good so I tried the same prop that I'm running on the 40 FSR. With that prop the 46 wanted to run around 13,800 rpm's. When I pulled the nose up she gained a few 100 rpm's. It was pulling like a big dog but I don't think many would want to be around her running that many R's (she really sounds like a wild child). So I guess I'll bench her until I can get some 12/4 props. I appreciate your input, Gary
Gary Anderson
