  • June 23, 2025, 02:10:18 AM
Author Topic: OS 46 VF venturie size, and gloplug recomendations  (Read 1576 times)
Offline Peter Nevai
    • C3EL
« on: June 07, 2011, 08:14:50 PM »
Hi Randy, Brett,
What is the proper venturie dia, and glow plug for the OS 46 VF? Also Randy do you have header pipes for the motor, just in case?
Re: OS 46 VF venturie size, and gloplug recomendations
« Reply #1 on: June 07, 2011, 09:10:53 PM »
Hi Randy, Brett,
Hi Peter
275 to 285 is the normal setup, as with most stunt setups you want a hot plug, T Bolt RC, Big Bore, Glo Devil 300 are all good, as are Enya # 3 and 4, plus Sig RC long
I have headers and pipes in stock for the VFs
The spray bar should be .157 diameter with the above, A Few used a .130s with the venturies and got not so good  runs
Offline Peter Nevai
    • C3EL
« Reply #2 on: June 08, 2011, 01:42:21 PM »
Thanks Randy,
Brett also reccommends the .275 venturi. I've checked the usual Internet Big Box stores for TBolt, Glo Devil, Enya plugs. No one lists those, predominantely OS, and Fox plugs seem to be the supermerket brands. Do you know off hand who can supply the any of the ones you mentioned? In your oppinion which of these brands is the most durable, as I'll probably get 10 or more as long as they are not 10 bucks each.
There are 3 Sig plugs the third one is the best right?.
SIGGP001 4 stroke plug
SIGGP002 SIG TUNED PIPE GLOW PLUG 1-1/2V LONG THREAD
SIGGP003  SIG R/C LONG GLOW PLUG WITH IDLE BAR 1-1/2V
The only Glo Devil plug.
Glow-Devil Plug SOT310 SONIC TRONIC GLO-DEVIL STD PL L 1-1/2V 12
Enya Glo plugs, forget about it, If you can find them available they are in the $7 + range.
The Thunderbolt plugs I've found are around 12 bucks a pop.
Seems like it's The sig or Glo-Devil plug if the one listed is the right one.
« Reply #3 on: June 08, 2011, 04:38:34 PM »
Thanks Randy,
I have all of the plugs in stock. the T Bolts are 5.50 and the Glo Devil #300  are also Enyas are  8.95
