  • June 21, 2025, 12:12:13 PM
Author Topic: Super Tigre 21 / 51  (Read 880 times)
Super Tigre 21 / 51
« on: August 16, 2013, 06:06:11 AM »
Does THIS Exist ?
Is it a Fake , or a Forery .
Anyone ever seen one , or INSIDE ONE ? alledgedly a 1 mm overbore 46 with V 51 Liner . perhaps .
Some of the G 15 / 19s have the 15 eradicated in the like manner , and lug stamped 19 . Some they try to knock the bypass in , stamping the 19 there . Did the apprenice do the machineing
on this one .  >:(
Would be intrested in anything about these . Mr Rabes 51 / 46s were stroked , ground offset smaller crankpin , acoding to the photos . This appears to be a FACTORY Job & larger bore .
and some lucky ? mug got it for $ 66 off Ebay . Not I , sadley .   H^^
Offline richardhfcl
  • AMA 82448
Re: Super Tigre 21 / 51
« Reply #1 on: August 16, 2013, 09:25:34 AM »
Matt,
     It's for real.  We had one like it five or six years ago knocking around our field.  With custom venturi
it still didn't work all that well as a stunt engine, and it was eventually passed on to one of the novice members
of the club.  On the other hand, it is a really neat looking engine.
     Richard Ferrell
Richard Ferrell
AMA 82448
« Reply #2 on: August 28, 2013, 01:00:19 AM »
humph , thought Id solved it , as figured they were BOTH lite case 60 based cases with the No machined OFF , & stamped ' 51 ' but that there RV has ' 21 ' cast in , so its definately the 21 / 29-35=40=46 CASE !  :P
« Last Edit: August 28, 2013, 05:43:26 AM by Matt Spencer »
