Engine basics => Engine set up tips => Topic started by: M Spencer on August 16, 2013, 06:06:11 AM
Does THIS Exist ?
(http://i.ebayimg.com/t/VINTAGE-C-L-MODEL-AIRPLANE-ENGINE-STUNT-COMBAT-SUPER-TIGRE-G-21-SATURNO-a48-/00/s/NDgwWDY0MA==/z/6W8AAMXQBlJSAD1h/$(KGrHqRHJFcFHoTkvDejBS!D1hE22w~~60_3.JPG)
Is it a Fake , or a Forery .
(http://i.ebayimg.com/t/VINTAGE-C-L-MODEL-AIRPLANE-ENGINE-STUNT-COMBAT-SUPER-TIGRE-G-21-SATURNO-a48-/00/s/NDgwWDY0MA==/z/UNoAAOxyhSBSAD1g/$(KGrHqNHJBsFHeN22Jd)BS!D1fr!o!~~60_3.JPG)
Anyone ever seen one , or INSIDE ONE ? alledgedly a 1 mm overbore 46 with V 51 Liner . perhaps .
Some of the G 15 / 19s have the 15 eradicated in the like manner , and lug stamped 19 . Some they try to knock the bypass in , stamping the 19 there . Did the apprenice do the machineing
on this one . >:(
Would be intrested in anything about these . Mr Rabes 51 / 46s were stroked , ground offset smaller crankpin , acoding to the photos . This appears to be a FACTORY Job & larger bore .
and some lucky ? mug got it for $ 66 off Ebay . Not I , sadley . H^^
Matt,
It's for real. We had one like it five or six years ago knocking around our field. With custom venturi
it still didn't work all that well as a stunt engine, and it was eventually passed on to one of the novice members
of the club. On the other hand, it is a really neat looking engine.
Richard Ferrell
(http://static.rcgroups.net/forums/attachments/4/2/2/9/4/6/a6054062-7-Ref%20Letter%201382.jpg) %^@
humph , thought Id solved it , as figured they were BOTH lite case 60 based cases with the No machined OFF , & stamped ' 51 ' but that there RV has ' 21 ' cast in , so its definately the 21 / 29-35=40=46 CASE ! :P
