  • June 20, 2025, 11:49:55 PM
Author Topic: Remote glow igniter lead  (Read 1219 times)
Online Mike Scholtes
« on: October 03, 2016, 05:05:57 PM »
Recently I saw a post featuring a remote glow igniter lead, that allows the igniter to be attached to the model far from the prop. It was very clean and neat, using a mini-RCA type jack to plug into the fuselage. I have looked at DuBro and Sullivan and it is not one of their products. I did a search here but did not turn up what I was looking for. This item would connect to the plug inside the cowl and run a lead back to the side of the fuselage somewhere. Anyone have a lead on this lead?
Re: Remote glow igniter lead
« Reply #1 on: October 03, 2016, 07:00:23 PM »
I did this on one of the F-86D's I built. Long time ago! I think it was a male/female Dean's connector, the male end was recessed into the side of the fuselage so that the female end from the power source would plug right into the fuselage, very clean and cool because my battery was built into a model of the ground power unit the full size 86's used. The wiring from the airplane side had a tiny alligator clip which went on the glo-plug and the ground wired to a mounting bolt. An RCA jack will work but they are big and will need a good solid mount
Offline Russell Shaffer
Russell Shaffer
Klamath Falls, Oregon
« Reply #3 on: October 03, 2016, 08:40:05 PM »
Thanks Russell, that's the one! Or actually, those are them!
Had dinner in Klamath Falls once on the way home from a FF contest in Oregon. Pretty town. Probably lots of good fishing and hunting in the area.
