I have plenty of larger and smaller engines, but I only have one .25 engine. It's a .25 FP on a Flite Streak ARF. I'm feeling pretty timid in pushing my learning curve, as I don't want to break the plane and not have another beginner plane on standby. I thought that, since I just bought a nice little belt/disc sander, I'd cut out two or three Flite streak kits and have a fleet on hand so that I'll be bolder in pushing my learning curve. But I don't want to pay eBay prices for another .25 FP to have ready to go.
I do have a Super Tigre G25 X-Serie ball bearing engine that's not doing anything right now. It's a R/C engine, and I thought I'd just run it with the R/C carb for now. I don't want to drop money into a custom made venturi with spraybar assembly. I'm planning on running an APC 10x4 prop, as that's what I am running on the FP right now. So, my question is this. Do I 1) Wire the throttle full open and set the needle to get the RPM I want, or 2) Peak the RPM with the throttle wide open, and then set the throttle back to the RPM that I want.
I know that either way, it won't be as consistent as a proper C/L venturi, but I'd think I'd want to peak it out at WOT and then set the throttle to the RPM I want, since this would give me the better fuel economy. What do Y'all think?
Mark
