Engine basics => Engine set up tips => Topic started by: Mike Scholtes on October 03, 2016, 05:05:57 PM
Title: Remote glow igniter lead
Post by: Mike Scholtes on October 03, 2016, 05:05:57 PM
Recently I saw a post featuring a remote glow igniter lead, that allows the igniter to be attached to the model far from the prop. It was very clean and neat, using a mini-RCA type jack to plug into the fuselage. I have looked at DuBro and Sullivan and it is not one of their products. I did a search here but did not turn up what I was looking for. This item would connect to the plug inside the cowl and run a lead back to the side of the fuselage somewhere. Anyone have a lead on this lead?
Title: Re: Remote glow igniter lead
Post by: Don Hutchinson AMA5402 on October 03, 2016, 07:00:23 PM
I did this on one of the F-86D's I built. Long time ago! I think it was a male/female Dean's connector, the male end was recessed into the side of the fuselage so that the female end from the power source would plug right into the fuselage, very clean and cool because my battery was built into a model of the ground power unit the full size 86's used. The wiring from the airplane side had a tiny alligator clip which went on the glo-plug and the ground wired to a mounting bolt. An RCA jack will work but they are big and will need a good solid mount
Post by: Russell Shaffer on October 03, 2016, 08:08:45 PM
Horizon Hobby has several.  Most any hobby shop can order it for you or you can go direct.
http://www.horizonhobby.com/SearchDisplay?searchTerm=remote+glow&categoryId=&storeId=10151&catalogId=10051&langId=-1&pageSize=40&beginIndex=0&sType=SimpleSearch&resultCatEntryType=2&searchTermScope=2&showResultsPage=true&searchSource=Q&pageView=
Post by: Mike Scholtes on October 03, 2016, 08:40:05 PM
Thanks Russell, that's the one! Or actually, those are them!
Had dinner in Klamath Falls once on the way home from a FF contest in Oregon. Pretty town. Probably lots of good fishing and hunting in the area.
