  • June 21, 2025, 07:08:08 AM
Author Topic: OS 46AXII ABL  (Read 1858 times)
Offline Tom Schwartz
OS 46AXII ABL
« on: May 09, 2016, 05:47:14 AM »
Any idea if these are good for stunt use with a venturi or wiring open the carb? The amount of new CL engine suppliers is really drying up..... :-[
Re: OS 46AXII ABL
« Reply #1 on: May 09, 2016, 11:30:44 AM »
I don't know, but they're heavy, and timed to make tons more power than a 46LA -- which is already capable of flying a 4-pound plane nicely (I have such a combination, which works great to my continuing astonishment).
If you want to experiment -- go ahead.  You may want to try the 32 as well.  Use a flatter prop than most use now, run a higher RPM, and (possibly) an smaller venturi than you'd use on an LA (but maybe not -- Brett Buck says that for similar sized airplanes you always seem to end up with similar sized venturis, no matter the engine displacement.  He seems to be always right, so he's not someone to ignore).
It'd be interesting to know how the current-production Magnum and ST engines work, too.
And -- there are current-production engines made specifically for stunt, they're just not in the Tower catalog for easy one-stop ordering along with a new quadcopter.  Check with Randy Smith and/or Dub Jett, or find the Stalker web page, or the contact information for Kaz Minoto (sp?).
Re: OS 46AXII ABL
« Reply #2 on: May 09, 2016, 02:14:02 PM »
Thanks for the leads. They sound more promising than what I am hoping to achieve. I guess I'm looking for another engine as reliable and affordable as the LA46, and I'm not yet ready to go electric.
Tom
Re: OS 46AXII ABL
« Reply #3 on: May 09, 2016, 02:16:27 PM »
Tom
eBay, until the supply dries up.  I'm pretty sure that a Stalker isn't much more expensive than the AXII, and it certainly has a following.
Offline Bob Matiska
Re: OS 46AXII ABL
« Reply #4 on: May 09, 2016, 03:00:10 PM »
Tom,
You know, you could call me and ask if I have anything to get rid of... Just sayin...
Bob
AMA 56267
