  • June 04, 2025, 12:12:38 PM
Author Topic: Chicken Hopper Tanks.  (Read 1381 times)
Offline Chris Wilson
« on: May 20, 2010, 09:06:33 PM »
Hi all,
I have had this discussion on other sites and it can get very personal ....... and confusing.
I fly diesels in stunt and need an abrupt cutoff at the end of the run so I would like to use chicken hopper tanks since they 'seem' the best for this effect.
Anyone see this differently? What designs would you advocate and why?
Thanks.
MAAA AUS 73427
Offline Dennis Moritz
Re: Chicken Hopper Tanks.
« Reply #1 on: May 21, 2010, 09:50:02 AM »
In my experience tank offset has the biggest effect on shutoff. Kick (offset/slant) the back  of the tank out from the circumference of the flying circle.
Offline Jim Thomerson
« Reply #2 on: May 21, 2010, 02:10:16 PM »
I've been flying diesels in Old Time Stunt, using regular metal uniflow tanks for more than 10 years with no problems with cut off.  Some will burp a couple of times before they cut off; others just quit.
Offline RogerGreene
« Reply #3 on: May 23, 2010, 11:07:31 AM »
Chris,
What diesel engine do you use for stunt? Also, what wing span plane etc?
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
« Reply #4 on: May 25, 2010, 05:10:57 PM »
Chris,
Roger
I use a 52" Freebird powered by a PAW 40, a 42" Mercury Monarch powered by a PAW 19 and an MVVS 40 converted to diesel that will most likely find a home in anther Freebird but could be enlarged slightly if the engine appears more capable than the PAW.
I have had engine runs that end with a 'burp..........burp............burrrrrrrp,' for a couple of laps and while that is not critical in itself it can be annoying.
Cheers.
MAAA AUS 73427
Offline Steve Thomas
« Reply #5 on: May 25, 2010, 08:43:29 PM »
Didn't realise you had the Freebird finished already, Chris.  How does it fly?  Let's see some pics!
Offline Larry Fulwider
« Reply #6 on: May 25, 2010, 09:53:04 PM »
Dennis has the sure cure.  y1
Numbers? 1/4" of taper (or slant) per 4" of tank length is enough for all but the wildest of yaws. Applies to clunks, uniflows, soup cans, and even rusty old Veco tanks. The "bbrrrp . . . brrpp . . .  brppp" end of run stuff simply disappears. The engine dies like someone ran a wooden stake through its heart.
      Larry Fulwider
Offline Chris Gilbert IRL-1638
  • EI-1638
« Reply #7 on: June 13, 2010, 04:19:15 PM »
Hi Chris,
Did you build the tank as drawn on the freebird plans? From what I recall its a rear feed hopper design.
I don't have full scale drawings of the freebird design, but I do have the original article and reduced plans for the inverted motor version, and the tank design is shown on the drawings.
Chris
IRL-1638
