  • June 24, 2025, 11:07:11 AM
Author Topic: K&B 40 [ 8011 ] : Stunt Friendly ?  (Read 1264 times)
Offline Robin_Holden
« on: June 06, 2010, 01:23:39 AM »
Hi fellas and greetings from S.W.France.
Is there anyone who has experience with a K & B 40 please ?
I've recently acquired one in great condition , converted to C/L .
It's VERY noisy !
Any suggestions to make it more 'stunt' friendly guys ? I've tried all I know without success ..... !!
Much obliged for any contributions ,
Kind regards ,
Robin [ ex-pat Brit in the Charente full of ex-pat Brits ! ]
Re: K&B 40 [ 8011 ] : Stunt Friendly ?
« Reply #1 on: June 06, 2010, 10:36:42 AM »
Sorry guys , I made an error when I said this was an 8011 Series.
The old box that the engine came in says it's a  4011 Series.
I've no experience at all of K&B so any information would be appreciated.
Thanks ,
Robin.
Offline philip metzner
  • chevyiron420
« Reply #2 on: June 07, 2010, 12:35:08 AM »
Robin, i have one of those engines in my box for future use. I have only test run it once a long time back, so i cant comment on how well it runs. I do remember reading that there are some people who use them for stunt so i'm sure its doable.
Offline Jim Thomerson
« Reply #3 on: June 07, 2010, 12:50:16 PM »
I have flown a K&B 4011 in both Old Time and modern stunt.  It is a favorite engine.  It is a more powerful engine than the Tower 40 (also a favorite).  I run in a rich two stroke.  I used an APC 11 x 5 prop, Sig champion 10% nitro, 20% oil 50/50 synthetic/castor. Fox 2-volt long plug.  Stock muffler with muffler pressure to a uniflow tank.
« Reply #4 on: June 07, 2010, 03:03:06 PM »
I also have one that runs very well. I bought it so I could turn the cylinder 180 degrees to get the exhaust on the outside of the circle. I took the big head gasket out and put in a thinner one and also made the venturi ~ .270" by putting a piece of 5/16 brass tube in it. Good engines.
Don
« Reply #5 on: June 07, 2010, 11:47:27 PM »
Thanks guys for the advice , I'm very much obliged to you all.
Regards from a misty France ,
Robin.
« Reply #6 on: June 14, 2010, 01:20:26 AM »
There pics on Mecoa site of which is which. 3 models .
Some have beefyer guts than the series 71 Ive got in a
57 Oz ship. 11 x 5 prop .P-head blew 8 plugs.
P is apparently the FAI no nitro pylon race head.
So a late ABC should easily exceed 160 mph ,
As its a much touger development of a series.
Just glared at one on ebay. 8011 is basically series 71 with muffler lugs .
other two current series have SRII schneurle? based front end, rod, etc.
61 ,- 64,- 67,- 70,- and 71 TORPEDO .
THAT WOULD. also suitable for STUNT.
(Just dont get a lean run , after dusk, with a dark red aeroplane . . . )
« Last Edit: June 14, 2010, 07:01:57 PM by Matthew Spencer »
