  • July 11, 2025, 03:32:28 PM
Author Topic: Brodak Aviastar engines  (Read 16966 times)
Offline Luiz Ribeiro
    • Ribeiro's Home Page
Re: Brodak Aviastar engines
« Reply #50 on: May 13, 2010, 04:31:05 PM »
Bill! Sorry for the delay in answering your post.
I received the new cylinder and piston from Brodak by the end of February. They shipped it on Feb/09 and didn’t bill me for this. The long time spent (almost 20 days) until I received it was due Brazilian Post Offices and Customs. The new play has a better compression than the original even though I can’t say it has a high compression (it is more acceptable and reliable than the first one).
Bench running and after braking in it again, I got the follow numbers:
Propeller 12.5X5 (Master Airscrew Classic):
9500 rpm (4-2 cycles) X 11200 rpm (max speed) : without muffler, Fox long plug
9700 rpm (4-2 cycles) X 11500 rpm (max speed) : without muffler, Enya 3 plug
9400 rpm (4-2 cycles) X 11200 rpm (max speed) : with Enya .61 stock muffler, Enya3 plug
Propeller 13X4 (Master Airscrew K-series):
10200 rpm (4-2 cycles) X 11600 rpm (max speed) : without muffler, Fox long plug
  9400 rpm (4-2 cycles) X 11300 rpm (max speed) : with Enya .61 stock muffler, Fox long plug
Propeller 13X4 (Zinger):
9200 rpm (4-2 cycles) X 10700 rpm (max speed) : without muffler, Fox long plug
8900 rpm (4-2 cycles) X 10400 rpm (max speed) : with Enya .61 stock muffler, Fox long plug
These numbers are very similar to those obtained with the original set, and they are not bad as remarked before. It was easy to start (hot or cold) and ran continuously and smoothly as the original.
I showed the engine, already with the new piston and cylinder installed, to a person here who builds RC and C/L engines and told him the results of the bench runs. He suggested me to put the engine in a plane and fly. Although he prefers more compression, he considers that the only way to get a conclusion is flying and that the engine can performs well and lasts for a long time even without a stronger compression.
 By now I don’t have a plane to install the .61 Aviastar, only a Strega ARC kit from Brodak that I bought together the Aviastar in last November, thinking in installing the engine on it. By many reasons, including the engine, I didn’t mount the plane yet. The C/L planes that I have ready to fly are a Vector 40 ARF, bought from Brodak, and mounted a year ago, and a Pathfinder ARF (Brodak kit) that I bought more recently from Martin Quartin in Brazil, who has a control line store here.  As I don’t fly C/L since a long time, only RCs, I bought the Vector and a .46 OS C/L LA engine to train, but until now I didn’t fly with it. I recently decided to mount the Pathfinder, that is more appropriated to restart with C/L, and installed the OS .46 LA of the Vector on it. The Vector is reserved for the next step and the Strega, maybe, for the further.
So, I can’t test the Aviastar in flight now. It would be very good if any body else, who has a plane to  install it, could fly and test the engine in flight as proposed in a prior post, by Bob Z, in this Forum.
Luiz
« Last Edit: May 27, 2010, 05:51:10 PM by Luiz Ribeiro »
« Reply #51 on: June 04, 2010, 07:35:42 AM »
To finish with my bench runs:
I ran the Aviastar .61 with an APC 13X4 (Sport) propeller, the same prop that Martin Quartim was running with authority in his Brodak Strega, equipped with an Enya ABC Pro .61 CXS.
The Aviastar always started on the first or second flip (after choking with two flips), when cold, in despite of its lower compression. I used the stock venturi (8 mm) in all runs. Got the following #s in the bench:
9900 rpm (4-2 cycles) X 11100 rpm (max speed): with Enya .61 stock muffler, Fox Long plug
9800 rpm (4-2 cycles) X 11100 rpm (max speed): with Enya .61 stock muffler, Enya3 plug
Seeing Martin's posts in this forum:
http://stunthanger.com/smf/index.php?topic=16881.msg154996#msg154996
Or in this other: http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=106&topic_id=1660&mesg_id=1660&page=#1824
We can conclude that the Strega, with the Aviastar .61, could be launched with the same 10400 rpm (rich 2 cycles) and the same APC 13X4 Sport prop he was using in his Strega, with the Enya .61 Pro CXS, with the same power and torque, necessary to pull it with authority.
Remains to know its behavior in flight and the possibility of run away, which can be solved as proposed by Bob Z, if it happens.
Ps: One thing that I forgot to mention in the prior posts is that the engine always showed a very strong pinch of the piston on the top of cylinder, even when the first cylinder/piston assembly was installed, what doesn't necessarily mean a high compression.
Luiz
« Last Edit: June 07, 2010, 06:56:27 PM by Luiz Ribeiro »
Online Motorman
« Reply #52 on: August 14, 2015, 03:01:22 PM »
Did a search and found this old thread. Ok so 5 years down the line. Does anyone have experience with the Brodak Aviastar 61?
Offline Bill Johnson
« Reply #53 on: August 15, 2015, 04:46:06 PM »
Here is a newer thread on the engine:
http://stunthanger.com/smf/index.php?topic=32116.0
Best Regards,
AMA 350715
