I start using a new Enya 61CX and this one is bit different then the first. The first one is an engine that has been used for more then a year with different people, who insisted in trying to make it work like an ST 60, using the same props and all, it didn’t work right of course. Anyway this engine end up in my Strega and ran mighty well as I have reported above.
My second engine is brand new with about 1 gallon of fuel and it is not running as strong as the first one. For trying the new Engine I used the same setup, exact same venturi, glow plug, fuel and prop. On the bench it was about 600rpms less in the exact same configuration, having tested both one after another. I put it on the Strega and I noticed a big difference in power. It was not as loud, it run mostly 2-2-2, and I had to round more in the corners. The engine is still new so probably it will get a little better with more running. I had bit difficulty making the first loop of the clover leave with moderate wind, the rest seems ok.
To get more power, I replaced the low compression button head for the high compression and it indeed worked better and it seems it did a bit of 4-2-4, but it still doesn’t growl like the first one.
Not noticing any sign of pre ignition I replaced the Enya 4 plug for the Enya 3 and it worked stronger and better, no sign whatsoever of pre ignition. The first engine with the lower compression head would not work with the Enya 3 plug.
With the R/C high compression head and the Enya 3 plug I got better power and it is burning less fuel then the first engine.
The only internal difference I could find between the two engines was the deck height, the second one 0,0043 deeper. That could mean that the liner in the first engine is mounted a bit lower on the block, or the liner lip is a bit thinner, thus more compression.
This is a video of Second engine running with low compression head and Enya 4 plug. Not bad actually for the engine, now for the flying well it was me at the controls.
With the 1st engine I can make a bit tighter corners, and plane seems to fly a bit more firmly too.
Martin
