  • June 24, 2025, 04:15:12 AM
Author Topic: Moulded nylon fuel filters coming apart.  (Read 717 times)
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« on: April 25, 2010, 08:26:57 AM »
The oil seeps into the joint and the filter comes apart. These are from a major prop maker.
I degreased it and put on a drop of CA.
What has been your experience with this?
AMA 77370
Offline Allan Perret
  • Proverbs
Re: Moulded nylon fuel filters coming apart.
« Reply #1 on: April 25, 2010, 08:35:38 AM »
The Master Airscrew filters are known for leaking / sucking air at the 2 piece body seam.   Pretty much everybody that uses them seals the body with CA or epoxy.  Best to do it when new, before you get fuel/oil in them.  I like them because of the small size.  No other issues once you get them sealed.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: April 26, 2010, 11:17:09 AM »
I agree, and they are CHEAP! LOL!! Bob Hunt first turned me on to them.
Mongo
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: April 26, 2010, 02:34:23 PM »
I use the MA filters for almost everything. I put a piece of heat shrink tubing over them, it seals the seam and the little shrink over the end holds them together.
