Engine basics => Engine set up tips => Topic started by: Greg McCoy on April 25, 2010, 08:26:57 AM
The oil seeps into the joint and the filter comes apart. These are from a major prop maker.
I degreased it and put on a drop of CA.
What has been your experience with this?
The Master Airscrew filters are known for leaking / sucking air at the 2 piece body seam. Pretty much everybody that uses them seals the body with CA or epoxy. Best to do it when new, before you get fuel/oil in them. I like them because of the small size. No other issues once you get them sealed.
I agree, and they are CHEAP! LOL!! Bob Hunt first turned me on to them.
Mongo
I use the MA filters for almost everything. I put a piece of heat shrink tubing over them, it seals the seam and the little shrink over the end holds them together.
