  • June 23, 2025, 06:07:20 PM
Author Topic: Brodak .25?  (Read 2499 times)
Offline frank mccune
Brodak .25?
« on: June 09, 2014, 09:56:39 AM »
      Hi All:
      Yesterday, I got to fly my "new" Bridal .25 powered Super clown.  This engine is very impressive! It was very fast with an 8X6 prop running at a rich two cycle! It was very easy to start and needle.
     My question is this: what kits will work well with this engine.  I think that it has as much power as the Fox .35 Stunt so can I just swap the Bridal into planes that have the Fox .35 engines installed?
     New kits that I have that the Brodak may be a good candidate for are:
Midwest P 51 48" w.s.
Sterling P 51        Sig foam winged P 51
Sterling Hellcat
CG Buster
CG Shoestring
     Perhaps the CG Buster would be a great combination.
    I do not know how large of an airplane the B 25 will pull.  Any suggestions?
        Tia,
        Frank
Offline Andrew Tinsley
Re: Brodak .25?
« Reply #1 on: June 09, 2014, 12:08:17 PM »
Hi Frank,
What is a bridal .25? Is it some sort of Brodak twin cylinders married together? Or am I missing something?
Andrew.
BMFA Number 64862
Re: Brodak .25?
« Reply #2 on: June 09, 2014, 04:48:35 PM »
     Hi Andrew:
     I will attempt to answer your question again.  My spell checker changed brodak to bridal and I did no notice the change! Lol
        Stay well,
        Frank
Offline Steve Fitton
Re: Brodak .25?
« Reply #3 on: June 09, 2014, 07:15:45 PM »
Try marrying off the Brodak 25 to the Buster or Shoestring.  The Sterling P-51 would be good too if you replace the stone kit wood.
Offline Balsa Butcher
  • High Desert Flier
Re: Brodak .25?
« Reply #4 on: June 11, 2014, 05:08:09 PM »
I think the CG Buster and Shoestring are at the large end of the spectrum for the B-25 but would work. Better though would be the next size down...ie: SkyRay, Shark 402, FliteStreak, Sakitumi.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Richard Koehler
Re: Brodak .25?
« Reply #5 on: June 12, 2014, 06:21:49 PM »
Try a Brodak VAMPIRE.
Re: Brodak .25?
« Reply #6 on: June 13, 2014, 01:26:29 AM »
A Goldberg Shoestring weighs 28-30 ounces with a slightly smaller wingspan than a Skyray. My SS is a wonderfully snappy sport flyer and a bit too fast with a Thunder Tiger Pro BB 25. A PB 25 like the Brodak should be perfect for it. The Brodak Shoestring might be a little lighter. They're great looking planes too, except to me, the traditional colors kind of suck. I went red and black to fix that.
Rusty
  • High Desert Flier
Re: Brodak .25?
« Reply #7 on: June 13, 2014, 11:15:40 AM »
I have run a stock B-25 in a 26 ounce Shark 402 which is smaller and lighter than most Shoestrings. It was seriously lacking in power hence the recommendation. Cure was an FP-25. If sport flying and lazy type maneuvers are your forte, it will be adequate.  If you go with a B-25, ues a larger venturi, it will help. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Re: Brodak .25?
« Reply #8 on: June 13, 2014, 01:46:43 PM »
I have run a stock B-25 in a 26 ounce Shark 402 which is smaller and lighter than most Shoestrings. It was seriously lacking in power hence the recommendation. Cure was an FP-25....
That's good to know about the B .25, thanks for clearing that up.
Online Geoff Goodworth
Re: Brodak .25?
« Reply #9 on: June 14, 2014, 01:32:33 PM »
The Goldberg, now Brodak, Shoestring has a 42" span and wing area of 395 sq in. Mine seem to finish at 28–29 oz and fly fine with an FP 20.
Re: Brodak .25?
« Reply #10 on: June 15, 2014, 02:09:18 PM »
      Hi All:
Sterling Hellcat
CG Buster
CG Shoestring
        Tia,
        Frank
Hi Frank,
I believe the Super Clown should be a great model for the Brodak .25.  I *think* you need a prop change.  6" pitch running a wet 2 will be fast on the right size model.  Think 9-4 for the Super Clown.
Of the other kits you list, the Sterling P-51, Sterling Hellcat, CG (or Brodak) Shoestring and CG (or Brodak) Buster will be very good with the right prop.  Again, I do not *think* any of the modern engines need 6" of pitch running a wet 2 unless you are flying in a Combat class.
BIG Bear
RNMM/AMM
