I picked up a fully built Cutlass at Delta Park, grabbed an OS 30 last trip home to slap in it and see why the previous owner gave up on it.
He had the tank set up for muffler pressure, but no muffler on hand. The engine is a converted R/C model, so it has a tapped blind hole in the center of the exhaust port. I had a barbed banjo fitting from an old solenoid valve, and it threaded into the hole.
I drilled the hole through to expose it to the exhaust stream, cleaned up the threads with a tap, and installed the fitting.
See Pics- I'll follow up with a flight report if it quits raining.
