  • June 21, 2025, 10:50:49 AM
Author Topic: The wrong fuel  (Read 2190 times)
Offline John KruziK
The wrong fuel
« on: April 12, 2007, 01:59:02 PM »
Maybe some one can help me out with a small problem, I bought a gallon of Powermaster 10 -22 fuel.  Ineed 10 -28 how can I get to 28% castor with out lowering nitro to much? Its for a fox 35    Thanks John
AMA 874027
Re: The wrong fuel
« Reply #1 on: April 12, 2007, 02:36:20 PM »
If I am not mistaken, 10-22 is 11% castor and 11% synthetic, correct me if I am wrong please.
there are 128 ounces of fluid in a gallon,
in 128 oz, there is 22 percent oil that equates to about 28 oz of oil,128 * .22=~28OZ
by adding 8 oz of oil, you will now have 36 oz of oil.
so,
128 = 8 =136oz total mix, 36 oz oil / 136 oz fuel = 26.5 % total oil, see some difference
so to get closer,, lets try 10 oz added oil
128 +10 =138  now there is 38 oz oil,, so 38/138 = 27.5% total oil
128+11 = 139  now there is 39 oz total oil,, so 39/139=28.05 % total oil
Thats how i get there,,
Online RandySmith
Re: The wrong fuel
« Reply #2 on: April 12, 2007, 02:44:40 PM »
Hi John
You can add 10.8 ounces to teh fuel that you bought, that will put it up where FOX super fuel is, however it will lower the nitro content, but it may not make much differance  this time of year, it is still cool  and you should get good power out of 8%
Offline Bill Gruby
Re: The wrong fuel
« Reply #3 on: April 12, 2007, 07:11:49 PM »
OK Everybody:
  Ole "Billy G" is gonna make this easy for you. Try this:
         http://www.nitrorc.com/default2.asp?Introduction=http://nitrorc.com/fuelws
   Read it if youwish but if you scroll to the bottom there are 2 boxes. One say oil the other nitro & oil--Click on what you want,fill in the blanks enter it and it does all the figuring for you. Simple. Go ahead and play it will give you the right answers every time, no guesswork.
  "Billy G"   ;D
Bill Gruby
AMA 94433
MECA 5393-10
Online RandySmith
Re: The wrong fuel
« Reply #4 on: April 12, 2007, 09:54:08 PM »
"""Read it if youwish but if you scroll to the bottom there are 2 boxes. One say oil the other nitro & oil--Click on what you want,fill in the blanks enter it and it does all the figuring for you. Simple. Go ahead and play it will give you the right answers every time, no guesswork."""
HI Billy G
One  BIG problem with the "right answer every time"  is,  A lot of fuel makers do NOT  use any standard formula for their fuel, many measure their fuel by what the components  weigh, so what the say is 18% oil is  really 14.7% oil, and  what they say  is  10% nitro is  really 7 to 8%  nitro, so there will always  be  some  guesswork involved  if  you are adding  to someone  else's  blend
Offline Bill Gruby
Re: The wrong fuel
« Reply #5 on: April 12, 2007, 11:28:55 PM »
Randy;
  I guess that means that you think this site is useless for mixing your own fuel? I'm done I won't post helpful info ever again.
  Thank-you;
           Bill Gruby  H^^
  If what you say is true about some manufacturers mixing by weight, then all the replies, yours included are guesswork because you really don't know what you have to start with? Yet you chose to quote mine, why is that?
« Last Edit: April 13, 2007, 12:08:36 AM by Bill Gruby »
Bill Gruby
AMA 94433
MECA 5393-10
Online RandySmith
Re: The wrong fuel
« Reply #6 on: April 13, 2007, 12:17:38 AM »
Randy;
  Thank-you;
           Bill Gruby  H^^
Hi Bill
 I wasn't  finding fault with you or picking on you, please don't get mad at what I wrote, just re read it, No where in the reply did I suggest you not post anymore . I just stated  the  facts about fuel,  and   YES  many fuel manufactures  DO  mix by weight  and  not  volume, matter of fact more do than don't. Reason is  Nitro  and  oil are both much heavier  than methanol, so they can make a gallon  cheaper  than a mix done by volume.  They also say it is the way the machines are setup to mix fuel.........
And YES  you are correct in stating  that all replies  including mine  are  guesswork  because  we  do not know  exactly what is in his fuel.  That is why  I stated  to add  10 ounces , it is better to guess  a little  high than be  low on oil  with a motor  that really  needs  28% oil
Offline Ralph Wenzel (d)
Re: The wrong fuel
« Reply #7 on: April 13, 2007, 01:41:54 AM »
John,
It depends on which Powermaster 10-22 fuel you started with. There are two: the "regular" 10-22 which is 11% Castor and 11% Synthetic (which you will never get to 28% all-castor!); and the GMA All-Castor 10-22, which is 22% Castor Oil (This one can be made into 28% All-Castor - Just use the numbers provided by others and add around 10 ounces of Castor Oil). The resulting % of nitro will be reduced from 10% (however it's figured by weight/volume) to around 9.3%, which isn't a noticeable change for anyone!
If I'm guessing correctly, you want the 28% for an old Fox/Johnson/K&B using an iron piston in a steel cylinder, and 28% all-Castor is proper. If the fuel you have is the "regular" 10-22 with 11% Synthetic Oil, save that for the modern stuff, like Brodak or OS LA/FP engines, and go buy a gallon of Powermaster GMA All-Castor 10-29, which is a fine blend for the old engines. This'll save you time and effort, and really won't cost any more in the long run; have you priced AA de-Varnished Castor Oil recently?
Ralph Wenzel
AMA 495785 League City, TX
Offline Michael O
    • Propellerhead
Re: The wrong fuel
« Reply #8 on: April 13, 2007, 02:49:04 AM »
Hi!
I have made an Excel spreadsheet that I have found useful for mixing my own fuel.
The file is 19.5 kB and contains no macros.
You can find it here: homebrewer.xls
Presuming 1 U.S. gallon is 128 fl.oz., using Alt. 2 in my spreadsheet yields the following result:
Add 10.7 fl.oz of oil to increase oil content from 22% to 28% (by volume).
/Michael
Offline John KruziK
Re: The wrong fuel
« Reply #9 on: April 14, 2007, 06:20:57 AM »
Thanks for all the help ,I have all the info I need.             John
AMA 874027
