  • June 15, 2025, 02:49:27 PM
Author Topic: after run oil  (Read 1312 times)
Offline Bootlegger
after run oil
« on: August 03, 2014, 06:39:56 AM »
 Guy's which after run oil do you use and why that one?
 I am using Marvel Mystery Air Tool oil in mine as it seems to protect the bearings well and cleans out easily when I prime the engine.
 I also hook up the glo driver after the last flight and prop out every bit of fuel that I can get out of the engine before installing the A/R oil.
 Your thoughts...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Thomerson
Re: after run oil
« Reply #1 on: August 03, 2014, 07:00:54 AM »
I use Rislone oil treatment.  It works fine with diesels as well.
Re: after run oil
« Reply #2 on: August 03, 2014, 07:55:33 AM »
Hi Gil,
I use air tool oil I got at Lowe's.  Not sure of the brand.  For storage (long term), I use 50/50 mix of that and Rislone.  The Rislone was George Aldrich's idea.
BIG Bear
RNMM/AMM
Re: after run oil
« Reply #3 on: August 03, 2014, 09:53:38 AM »
Marvel Air Tool oil, or most any Air Tool Oil  is the best thing to use, I cover this in the article I wrote for Flying Models some years ago.
You can get the air tool oil from Lowes , Home depot, Hobby Shops have after run oil, and Auto Parts stores most all have it
