  • June 21, 2025, 12:41:29 PM
Author Topic: 3-blade prop for LA46?  (Read 1578 times)
Offline Mike Scholtes
« on: February 15, 2008, 05:26:17 PM »
Anybody have a success story using a 3-blade prop on an LA46? I have this engine in three models: Imitation (631"), Olympic Mark VI (560"), and Vector 40 (536"). It likes a fairly flat 2-blade like the APC 12.25x3.75, but not sure how it would react with a 3-blade such as 11x4 Bolly or Eather.
Offline Jim Oliver
Re: 3-blade prop for LA46?
« Reply #1 on: February 15, 2008, 06:08:21 PM »
Mike,
As usual, I go contrary to conventional wisdom.  I am presently using only one OS LA46, on a Cardinal profile with 2 blade Zinger 12x5.  Take off at 7900-8000 rpm, 62 foot lines, eye-to-eye, Powermaster 10/22.  The down side of this set up is that it seems to need more fuel to fly the pattern than the high rpm type run.  Flew this at KOI a few weeks ago.
My point is that the engine will take more prop load than some applications would indicate.  One of the Master Airscrew 10x5 props might be a good place to start.
Cheers,
Jim
Jim Oliver
AMA 18475
Offline Steve Fitton
« Reply #2 on: February 15, 2008, 07:08:20 PM »
I have an LA-46 that really likes a Gator 10.75x3.75 three blade.  A Bolly 11x4 three blade will work as well.
Willis Swindell
« Reply #3 on: February 15, 2008, 08:36:09 PM »
I have a La 46 in a cardinal with a three blade 10x7 Master air screw which is really a 10x5 and works great. A three blade 11x7 air screw, which is a 11x5 is a little to much for the 46. I picked up a three blade 10x5 Master air screw at  the local H.S. and it pitched out to a 10-3 1/2 on my gage.
Willis
Offline John Cocking
« Reply #4 on: March 09, 2008, 04:30:25 PM »
Aah, a useful post. I will try the Master 10/5 3 blade shortly.
John Cocking, K2CQW: Philly Flyers & NorCal Circle Jerks
Offline Ray
« Reply #5 on: March 09, 2008, 07:39:31 PM »
Ah, Hah!  A non-negative comment!  How about that!  Still unnecessarily sarcastic, but looking at the sig, to be expected I suppose.
« Reply #6 on: March 10, 2008, 07:10:28 AM »
Ray, see my post on the other threads. (Fox 15, Fox 35)
Offline Larry Wong
« Reply #7 on: March 16, 2008, 01:24:52 PM »
You can try a Bill Lee 3 blade prop. they have narrow blades cut a 12" down to 11.3 x4 should put you in the ball park.
Larry
