Engine basics => Engine set up tips => Topic started by: Mike Scholtes on February 15, 2008, 05:26:17 PM
Anybody have a success story using a 3-blade prop on an LA46? I have this engine in three models: Imitation (631"), Olympic Mark VI (560"), and Vector 40 (536"). It likes a fairly flat 2-blade like the APC 12.25x3.75, but not sure how it would react with a 3-blade such as 11x4 Bolly or Eather.
Mike,
As usual, I go contrary to conventional wisdom. I am presently using only one OS LA46, on a Cardinal profile with 2 blade Zinger 12x5. Take off at 7900-8000 rpm, 62 foot lines, eye-to-eye, Powermaster 10/22. The down side of this set up is that it seems to need more fuel to fly the pattern than the high rpm type run. Flew this at KOI a few weeks ago.
My point is that the engine will take more prop load than some applications would indicate. One of the Master Airscrew 10x5 props might be a good place to start.
Cheers,
Jim
I have an LA-46 that really likes a Gator 10.75x3.75 three blade. A Bolly 11x4 three blade will work as well.
I have a La 46 in a cardinal with a three blade 10x7 Master air screw which is really a 10x5 and works great. A three blade 11x7 air screw, which is a 11x5 is a little to much for the 46. I picked up a three blade 10x5 Master air screw at the local H.S. and it pitched out to a 10-3 1/2 on my gage.
Willis
Aah, a useful post. I will try the Master 10/5 3 blade shortly.
Ah, Hah! A non-negative comment! How about that! Still unnecessarily sarcastic, but looking at the sig, to be expected I suppose.
Ray, see my post on the other threads. (Fox 15, Fox 35)
You can try a Bill Lee 3 blade prop. they have narrow blades cut a 12" down to 11.3 x4 should put you in the ball park.
