  • August 01, 2025, 07:48:19 PM
Author Topic: New Shoe  (Read 10695 times)
Re: New Shoe
« Reply #50 on: April 28, 2008, 03:43:12 PM »
RANDY, didnt you just this morning make a post about needing to think in terms of simple attractive schemes (on my oriental thread) yeah thats what I thought!  I really wanted to go nuts on this one but its purpose in life is again to be disposable with little emotion,, so the killer paint will wait, the 109 is about ready to feel the soft caress of 400 grit in prep for paint. And while its not extravegant, its involved.
in all seriousness, I always look forward to your schemes Randy they are without fail, different and attractive, now if I could get you to use what you know and quit experimenting  HB~> n1 LL~ LL~
of course the theory is your planes last longer than mine, so,, I guess its justified right?
Re: New Shoe
« Reply #51 on: April 28, 2008, 04:41:22 PM »
Yea, theory is just that. Yea, I'm vacillating between a really cool scheme I had an idea for and something very simple (and scale). It's a time factor, really. I'd like to have it done for the Regionals. Guess we'll see.
Online Dennis Adamisin
Re: New Shoe
« Reply #52 on: April 28, 2008, 05:59:53 PM »
K.I.S.S.  !
Re: New Shoe
« Reply #53 on: April 29, 2008, 08:47:18 AM »
Dennis,
We'll see. If I have the time, I may go with something more interesting. But truth is, I may just go simple.
I did discover something that I will use in the future. I had shot primer on the plane, but I felt it was kinda thin. So I mixed up some more and shot a second coat. Interesting part is. The gray of the first coat was quite a bit darker than the gray of the second. Consequently, when I started sanding last night, I discovered that as the primer came off, the low spots were highlight with the lighter gray primer. Very easy to see. It's a pretty neat trick. It will allow me to go back and hit those spots again when I'm done sanding. They really stand out.
Re: New Shoe
« Reply #54 on: April 29, 2008, 10:34:17 AM »
RP:
I remember that Bill's Shoestring what really set it off was the rivet work on top of a pretty simple color scheme.  The sure bet is that whatever you decide its going to look great.  Interesting note on the primer...
Re: New Shoe
« Reply #55 on: April 29, 2008, 12:26:51 PM »
Hi Randy,
I know you have used that trick (different colors when sanding) before............ ;D
I am really looking forward to seeing this model when finished!
Bill <><
Re: New Shoe
« Reply #56 on: April 29, 2008, 04:00:01 PM »
Bill,
Well, I layed the primer on so thick that I will be awhile sanding. Took two hours last night just to get the flaps done. I feel like I'm sitting in a sandbox full of powdered filler already and I haven't even started the main airframe yet.
I've decided to go with a compromise on the paint scheme. I'm going to use the scale-like scheme with a few flourshes. I don't suppose a bit of checkerboard will hurt it.
Offline Leo Mehl
Re: New Shoe
« Reply #57 on: April 29, 2008, 06:22:32 PM »
John,
Nope, no hole in the tank, but man that engine can suck fuel. 7 1/8oz for a 46? Yikes!  I may go back to the .40 just on fuel economy.
A 46 what. OS, st orwhatever. HB~>
Re: New Shoe
« Reply #58 on: April 30, 2008, 07:19:09 AM »
Hi Brother Leo,
Until Randy gets here, I will tell you what he told me:
It's an OS 46VF, set up by Tom Lay, on pipe.
Bill <><
Re: New Shoe
« Reply #59 on: April 30, 2008, 10:10:51 AM »
Bill,
Yea, that's it. I took it apart the other night and put in a slightly smaller venturi (from a .275 to a .270) and put a filter on ... and lost almost an ounce to get 6:30 flight. The first flight with the setup ran over 8 minutes! So I backed off to 6oz and got about 6:30 out of it. Hmm ... That is odd. But still seems to have plenty of power.
Offline Leo Mehl
Re: New Shoe
« Reply #60 on: May 02, 2008, 09:44:34 AM »
John, as long as it doesnt keep us from getting breakfast, in fact, let em all come, ,30 minutes after us so we can practice while they are eating!
as for the pathfinder, do like Pat must,, pump the wing full of helium, or maybe its just the lighter Boise air?
Mark, Mark, Mark,you know that boisw aire may be lighter but it iis also thinner which results in less lift. You know where the lifting hot air comes from.
Re: New Shoe
« Reply #61 on: May 02, 2008, 10:20:50 AM »
Yeah Leo, I do, I sure do,, some old short guy who keeps talkin all the time, thats where the hot air comes from  LL~ LL~
Re: New Shoe
« Reply #62 on: May 02, 2008, 11:11:40 AM »
I think you asked for that one, Leo.
Re: New Shoe
« Reply #63 on: May 02, 2008, 10:45:53 PM »
This .46VF is the one you were wondering about the funny bearing noise? And the fuel consumption is that high? I'd call PW and ask for his advise, but maybe the high fuel burn is from the bearing being bad? That's supposed to be a clue, but I really don't understand why bad bearings cause radically low MPG. Even new parts can be bad. ??? Steve
Re: New Shoe
« Reply #64 on: May 02, 2008, 10:50:45 PM »
I think in some cases the bearings leak fuel forward maybe? not sure they could leak enough to create Randys fuel crisis though
Re: New Shoe
« Reply #65 on: May 03, 2008, 09:05:33 AM »
Steve,
The noise went away. The engine had sat for a long time in the box. Maybe 3 years before I pulled it out to try it at the end of last year. Then it sat again all winter. Could just be excess gunk in the low end. At any rate, it seems fine now. The bearing always felt free, it was just the noise. I noted that the slight change in venturi and a filter seems to have had a large change in fuel mileage. At any rate, we are flying tomorrow at the Narrows, weather permitting, and I'll get a chance to do some more experimentation. Sure like the power output.
BTW, the primer is almost sanded. One wing surface and the open bays on one other then I can clean up the foot of dust on the shop floor, wipe down and shoot a clear seal coat. Hope to shoot some base color tomorrow.
Re: New Shoe
« Reply #66 on: May 03, 2008, 07:15:50 PM »
OK, it's ready for color. As soon as I get rotator cuff and Tommy John surgery to repair my arm from all the sanding, I'll shoot the base coat. Man, is my arm tired.
