  • June 19, 2025, 02:59:16 AM
Author Topic: Polyspan  (Read 1314 times)
Mike Griffin
Polyspan
« on: March 07, 2008, 08:41:49 AM »
When using polyspan for your covering and after the final doping, is a primer recommended before painting?
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Polyspan
« Reply #1 on: March 07, 2008, 09:36:32 AM »
I didn't even use a filler other than many coats of clear dope on two I finished and they both came out great.
Re: Polyspan
« Reply #2 on: March 07, 2008, 10:21:43 AM »
Like Bob, said, Polyspan fills easily.  If you're shooting for as 20 pointer, then use the primer, if you just want it to look great, dope will fill it.
Offline Jim Treace
  • 1979 600 Aerostar N79JT
Re: Polyspan
« Reply #3 on: March 07, 2008, 01:42:58 PM »
Mike, I am no expert at this, as I have only used polyspan once on my Cardinal. So, I had the same questions as you. I used nitrate to attach and it went on great, but I was caught a bit by the difficultly of pulling around corners or curves, like the wing tip. But after a while I got it OK. It states in the instructions that polyspan doesn't go around corners very well, they are correct. I used a little heat from hair dryer to shrink, be careful this stuff melts really quick and is kind of difficult to patch.
I only used butyrate over bays to seal. And only used my main color white, no primer. I think it turned out pretty good. Hope this helps.
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Mike Griffin
Re: Polyspan
« Reply #4 on: March 07, 2008, 08:21:18 PM »
Thanks Bob, Bill and Jim.  Really great looking plane Jim
Offline Bill Morell
Re: Polyspan
« Reply #5 on: March 08, 2008, 05:41:42 PM »
I have recently gone back to a dope finish and have been using poly span. I use nitrate dope and don't worry about it not being fuel proof as the color coats are that. I have been shooting primer on mine and then sanding with 320 wet. A tedious process and you have to be very careful not to sand through. From now on when I build a wing alot of prep work will go into EVERY part that the covering touches. No sharp edges. I have not had any problem covering the wing in one piece, tips included. It is a bit more work but worth it. When I have sanded through and have had to patch I use silkspan. I tear the patch, never cut with scissors. Makes it easy to sand and almost disappears.
Bill Morell
Vietnam 72-73
