  • July 09, 2025, 07:40:16 AM
Author Topic: Replacing motor mounts.  (Read 1903 times)
« on: October 16, 2011, 03:49:14 PM »
 Howdy folks,
 I'm currently leaning towards "bashing" an ARF Nobler as a next project. I'm thinking of doing a P-40 Tomahawk type thing with it. I really don't like the crappy wood that they have in it for the engine mount beams. Does anyone have any tips on removing them cleanly without butchering things like the firewall up too badly?
Re: Replacing motor mounts.
« Reply #1 on: October 16, 2011, 05:19:57 PM »
yep - drill a 1/8" holes in the front of the bearer (or large enough to get a screwdriver through) - heat the bearer glue with a heat gun and then "twist" the bearer off using the screwdriver through the hole in the front of the bearer.
with enough heat it will let go - if the bearer breaks -/splits - heat and use a wood chisel to lift it from the ply doubler thr glue in the ARFs is pretty weak - and the heat will make it let go
« Reply #2 on: October 16, 2011, 05:34:52 PM »
I gave my ARF Nobler to Dave Gardner.  That solved the problem.
Offline Chris Wilson
« Reply #3 on: October 16, 2011, 06:15:05 PM »
;D
Not for him it didn't!
MAAA AUS 73427
Offline Bootlegger
« Reply #4 on: October 17, 2011, 11:59:28 AM »
  I cut the soft mounts off at the front fire wall, then doubled the front fire wall and used an R/C moubt bolted to the front fire wall.  Works very well... y1
8th Air Force Veteran
Gil Causey
AMA# 6964
