  • July 07, 2025, 05:31:06 PM
Author Topic: Vertigo II Build  (Read 229105 times)
Online wwwarbird
Re: Vertigo II Build
« Reply #50 on: April 05, 2024, 07:55:19 PM »
I drew up the original set of plans in September of 2016 for use with a Stalker .61 with a built up wing that was 60 inches.
 Thanks Don, carry on!  :)
Offline Don Jenkins
« Reply #51 on: April 07, 2024, 06:20:02 AM »
Thank you Al and Wayne for the kind words.  I really got the "building bug" and I'm getting out to the shop several hours a day almost every day.  I tack glued the rear top block and got it rough sanded.  I use a lot of masking tape while sanding to protect surrounding areas.  I'll remove it and hollow it then once back in place do a final sanding.
Offline Don Jenkins
« Reply #52 on: April 08, 2024, 06:09:41 AM »
Sanding complete on the rear top block.  I used a piece of 1/4 inch masking tape to keep the area for gluing the fin/rudder straight and flat.
Offline Don Jenkins
« Reply #53 on: April 09, 2024, 07:20:05 AM »
The fin/rudder is complete.  I used incredibly hard 1/4 inch balsa that I thought I would never use, and sanded in an airfoil.  I don't plan on gluing it on until everything is covered with silk span.  On previous builds, I've dinged up the rudder quite a bit while flipping the plane over many times while doping, putting on silk span and sanding.  Might save a headache?
« Last Edit: April 12, 2024, 06:39:00 AM by Don Jenkins »
Offline Don Jenkins
« Reply #54 on: April 09, 2024, 07:26:52 AM »
I also made up the lead outs and did a good sanding on the entire plane.  I used sheet rock joint compound to fill in all the minor dings and flaws.  It works pretty good on bare balsa, but once dope goes on I use glaze putty.  Next I'll start working on cockpit details and applying dope.  I also need to make the fillet pieces for flaps and elevators which won't get glued on until after silk span is done.
Offline Don Jenkins
« Reply #55 on: April 09, 2024, 07:31:57 AM »
I installed the motor for these pics and found that I needed to sand a bit more on the inside of the top block to allow clearance for the motor.
Offline Don Jenkins
« Reply #56 on: April 10, 2024, 05:59:54 AM »
I started on cockpit details.  Nothing fancy or scale-like, just a seat back, headrest and instrument panel.  The instrument panel is 1/32 inch ply and I made the 1/4 inch holes with a Dremel bit.  I'll paint it flat black and use J-Tech gages glued to the back.
Offline Don Jenkins
« Reply #57 on: April 10, 2024, 06:01:24 AM »
I made the headrest by attaching a rounded piece of 3/8 inch balsa to a threaded Dremel bit and used it as a mini lathe against a sanding bar with 180 grit paper.  The seat back was sanded from a piece of 1/4 inch balsa.
Offline Don Jenkins
« Reply #58 on: April 10, 2024, 06:04:10 AM »
After some dope, primer and sanding, each piece will be painted flat black and glued in after painting the cockpit area flat black.  I use Testor's flat spray enamel for plastic models.  It works pretty good for this purpose.
« Last Edit: April 11, 2024, 07:30:52 AM by Don Jenkins »
« Reply #59 on: April 10, 2024, 07:40:57 AM »
After some dope, primer and sanding, each piece will be painted flat black and glued in after painting the cockpit area flat black.  I use Testor's flat enamel for plastic models.  It works pretty good for this purpose.
Don:
I ran across these looking for paints I could mix for cockpit, etc.  They are water based acrylic, cheap and come in a zillion colors.
https://www.hobbylobby.com/Crafts-Hobbies/Craft-Paint-Stencils/Acrylic-Craft-Paints/Crafter-s-Collection-Acrylic-Craft-Paint/p/533
A plane is not a plane without a cockpit !  What is cool about these colors is that they are very thick, intended for mixing.  I will be going over this color on mine with a cockpit gray then rubbing it some to give the worn look with the zinc chromate base.
I really like what you are doing, keep it up!
ken
Offline Don Jenkins
« Reply #60 on: April 10, 2024, 08:01:05 AM »
Very nice Ken!  You have way more patients than me when it comes to the cockpit!  I have been using water based paint for my pilot, should finish him up today.
Offline Warren Wagner
  • Bradenton, FL
« Reply #61 on: April 11, 2024, 09:18:51 AM »
Don,
Appreciate your taking the time to post a very comprehensive thread.  The photos and
captions were excellent.  The workmanship and engineering were pretty darn nice as well.
Good job.
Cheers.
Warren Wagner
Bradenton, FL
Warren Wagner
AMA 1385
Offline Don Jenkins
« Reply #62 on: April 12, 2024, 06:36:22 AM »
Thank you Warren, very kind of you.  Here is the paint scheme I plan on using.  I drew this up for my Dreadnought a few years back but never used it.  I will use all Randolph dope.
Offline Jeremy Chinn
« Reply #63 on: April 12, 2024, 03:08:51 PM »
Great thread.
Love the finish scheme.
Offline Don Jenkins
« Reply #64 on: April 13, 2024, 06:48:51 AM »
Great thread.
Thanks Jeremy.  How does that Brodak SV-11 fly?
Don
Offline Don Jenkins
« Reply #65 on: April 23, 2024, 06:36:38 AM »
I got my shipment of dope from Aircraft Spruce and 4 rolls of medium silk span from Easy Built Models.  While I was waiting for materials I cleaned my shop, which included painting the walls and base boards, which were covered with overspray from previous builds.  I also painted the pilot!  Now back to work on Vertigo II!
Offline Don Jenkins
« Reply #66 on: April 23, 2024, 06:48:20 AM »
I brushed 3 coats of non-tautening butyrate clear (thinned 50%) on the plane and all parts.  I also sanded lightly between each coat with 320 grit paper.  Now the fun starts with applying silk span.
Offline Don Jenkins
« Reply #67 on: April 25, 2024, 06:40:10 AM »
Applied silk span to some parts by wetting with a spray bottle, lay it on the part and brush on dope.  Then rub with finger to get good adhesion.
Offline Don Jenkins
« Reply #68 on: April 25, 2024, 06:42:37 AM »
Sanded the edges to remove the excess silk span with 320 grit paper and then brushed on another coat of clear.  I'll put on a total of 3 coats of 50% thinned clear before spraying with primer.
« Last Edit: April 26, 2024, 07:10:16 AM by Don Jenkins »
Offline Don Jenkins
« Reply #69 on: May 10, 2024, 09:11:31 AM »
I got distracted from the build for a while to do yard work and refinish my front door (honey do list).  Anyway I got some time to get into the shop and I finished applying silk span to the plane and all parts.  I also brushed on 3 coats of dope and sanded each coat with 320 grit paper.
Offline Don Jenkins
« Reply #70 on: May 10, 2024, 09:14:31 AM »
I'll epoxy the rudder in place next and use Super-Fil to make a fillet before I glue on the balsa fillet pieces for the stab/elevators that I still need to make.
Offline Don Jenkins
« Reply #71 on: May 10, 2024, 09:18:12 AM »
I did get the cockpit pieces prepped and painted.  I decided to make a 1/64 inch ply cockpit floor instead of trying to get the balsa cockpit floor prepared for paint.  It was easier and used a lot less material to finish.  I'll complete the instrument panel with J-Tech gages.
Offline Don Jenkins
« Reply #72 on: May 13, 2024, 06:56:45 AM »
I made the fillet pieces for the flaps.  I sanded a piece of 1/2 inch balsa with the tube and sanding bar method to an 1/8 inch taper.
Offline Don Jenkins
« Reply #73 on: May 13, 2024, 06:58:20 AM »
Then sanded a little at a time until I got a really nice fit between the flap and fuselage, then capped the ends with 1/64 inch ply.
« Reply #74 on: May 13, 2024, 10:33:15 AM »
Not too many people use wing flap fillets anymore.  I have no idea why.  They really help reduce tail flexing.
Nice - Ken
Offline doug coursey
« Reply #75 on: May 13, 2024, 11:12:23 AM »
I TACK GLUE THE FILLET TO THE FLAP AND SAND TO MATCH THE FLAP...PUT SOME MASKING TAPE ON THE FLAP SO YOU DONT SAND THE FLAP
AMA 21449
Offline Don Jenkins
« Reply #76 on: May 14, 2024, 07:36:31 AM »
That would certainly work, except in my case the trailing edge of the wing is 1/2 inch thick and the flaps are 3/8 inch.  That's the Randy Smith SV design.  So my fillets are slightly larger than the flap all the way to the trailing edge.
Offline Don Jenkins
« Reply #77 on: May 14, 2024, 07:38:27 AM »
I did cover the fillets with silk span before gluing into place.
Offline Don Jenkins
« Reply #78 on: May 14, 2024, 07:45:09 AM »
I used Super-Fil for the tail fillet.  I applied with a glue syringe then wipe with my finger wet with alcohol.  On the vertical flat section I used a piece of 1/32 inch ply wet with alcohol.  This makes the Super-Fil really smooth and it cuts down on sanding once cured.
« Last Edit: May 16, 2024, 04:27:08 AM by Don Jenkins »
Online wwwarbird
« Reply #79 on: May 14, 2024, 09:21:15 PM »
I use Super-Fil for the tail fillet.  I applied with a glue syringe then wipe with my finger wet with alcohol.  On the vertical flat section I used a piece of 1/32 inch ply wet with alcohol.  This makes the Super-Fil really smooth and it cuts down on sanding once cured.
 That's the way aha-aha, we like it aha-aha...  y1
Offline Don Jenkins
« Reply #80 on: May 15, 2024, 04:54:27 AM »
YEP!!!
Offline Don Jenkins
« Reply #81 on: May 15, 2024, 04:57:01 AM »
A light sanding on the Super-Fil with a brass tube wrapped in 220 grit paper then a second sanding with 320 and its ready for primer.
« Last Edit: May 23, 2024, 06:22:07 AM by Don Jenkins »
Offline Don Jenkins
« Reply #82 on: May 22, 2024, 05:09:41 AM »
I took a few days off to fly at Joe Nall at Triple Tree in Woodruff, SC.  A very nice venue with a decent turn out, and a really great group of people.  Now back to building.  I finished the wing fillets with Super-Fil.
Offline Don Jenkins
« Reply #83 on: May 22, 2024, 05:11:01 AM »
Light sanding with 180 grit wrapped around 3 different sizes of brass tubes and the fillets are complete.
« Last Edit: May 23, 2024, 05:29:39 AM by Don Jenkins »
Offline Don Jenkins
« Reply #84 on: May 23, 2024, 05:33:22 AM »
I made the elevator fillet pieces and covered them with silk span before gluing into place.  Next I'll use Super-Fil for the fillets.
Offline Don Jenkins
« Reply #85 on: May 23, 2024, 05:38:28 AM »
I spent a lot of time aligning the flaps and elevators with the adjustable push rod when installing the fillet pieces.  I think I got them really close to neutral.
Offline Don Jenkins
« Reply #86 on: May 24, 2024, 05:12:55 AM »
Completed the tail fillets, except for a light sanding.  I'll start working on the cockpit next.
« Last Edit: May 31, 2024, 06:49:59 AM by Don Jenkins »
Offline Don Jenkins
« Reply #87 on: May 24, 2024, 05:14:25 AM »
I finished the instrument panel.  I'll sand the groove for the canopy then paint the cockpit flat black.
Offline Jake Moon
« Reply #88 on: May 24, 2024, 11:42:12 PM »
It's been very entertaining and educational to follow this build thread—especially knowing the quality of the work on your planes. Thanks for doing it.
Offline Don Jenkins
« Reply #89 on: May 25, 2024, 06:09:04 AM »
You are certainly welcome Jake!  Thank you!
Don
Offline Don Jenkins
« Reply #90 on: May 25, 2024, 06:15:55 AM »
I sanded the area to attach the canopy.  Next I'll prep the area for paint.
Offline Don Jenkins
« Reply #91 on: May 25, 2024, 06:20:17 AM »
Canopy fit is pretty good.  I also learned a trick from Sparky concerning the Williams Brother pilot I'm using.  After some time in the sun in the hot cockpit the glue joint at the top of the head sometimes separates and it looks bad.  To prevent this, I drilled a hole in the bottom of the pilot and poured in a small amount of epoxy so it cures in the top of the pilot's head.
« Last Edit: May 31, 2024, 06:51:06 AM by Don Jenkins »
« Reply #92 on: May 25, 2024, 07:05:23 AM »
I drilled a hole in the bottom of the pilot ...
Is that legal? LL~  Is the hole in the back of the cockpit to keep the canopy from fogging or to give all of the little balsa flakes trapped in the fuselage a way out?    VD~
Looking good - Ken
Offline Don Jenkins
« Reply #93 on: May 25, 2024, 07:59:41 AM »
Looking good - Ken
The hole in the cockpit is to allow clearance for the flap horn and pushrod.  But even if there was not a clearance issue, I would still make a hole so the canopy won't fog, and to allow a place for all the balsa dust in the fuselage to escape and accumulate on the inside of the canopy.  That always makes me happy when that happens!  NOT!
I have a friend (that is truly a master builder) that was using low pressure air to blow out/off balsa dust on a plane and he inadvertently pressurized the inside of the plane through a hinge slot and blew out the silk span of an open bay.  OUCH!  Dust isn't really that bad.
Offline Don Jenkins
« Reply #94 on: May 27, 2024, 06:29:29 AM »
I prepped, primed, sanded and painted the cockpit area.  The question is, can I get the detail items installed without getting glue everywhere?
Offline Don Jenkins
« Reply #95 on: May 28, 2024, 06:00:11 AM »
I got all the cockpit pieces epoxied in without making too much of a mess.
Offline Don Jenkins
« Reply #96 on: May 28, 2024, 06:02:57 AM »
I got the canopy glued on without any issues.  Next I'll make a fillet with Super-Fil and once that is blended in, I'll shoot a coat of primer.
« Last Edit: May 30, 2024, 06:07:27 AM by Don Jenkins »
Offline Don Jenkins
« Reply #97 on: May 28, 2024, 06:14:00 AM »
I did a final assembly of all parts/pieces to ensure everything still fit properly after covering with silk span and brushing on 6 coats of clear.  I try to leave a large enough gap on all covers, flaps, and elevators such that when all painting is done everything still fits and moves freely.
Offline Don Jenkins
« Reply #98 on: May 30, 2024, 06:06:02 AM »
A lot of careful sanding with 4 different sizes of plywood with 180 grit stuck on...
Offline Don Jenkins
« Reply #99 on: May 30, 2024, 06:06:52 AM »
...and the canopy fillet is done.
