  • August 02, 2025, 05:52:20 AM
Author Topic: Urethane finishes ?  (Read 1628 times)
Offline Rob Killick
Urethane finishes ?
« on: May 13, 2007, 04:14:38 PM »
Hi ,
I've been going through several posts , concerning urethane finishes ( MinWax , mainly), but due to my location (Canada) , I'm having trouble discerning the differences between Canadian product names and U.S. names .
 At this moment I have a can of Minwax "Helmsman" spar varnish (urethane) . I'm wondering if this would be an "OK" finish , that would be a good fuel-proofer ?
Any input would be appreciated :)
Thanks !
Rob Killick , MAAC 33300
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Urethane finishes ?
« Reply #1 on: May 13, 2007, 04:22:37 PM »
the Helmsman spar varnish in the rattlecan is indeed fuelproof, at least as much as anything is.  I use it as a topcoat over paint that isn't, and it holds up well.  A surprisingly light coat is all that's needed. Besides that it's *shiny*.  Just give it a couple days to cure out before you fly.
--Ray
--Ray
AMA902472
« Reply #2 on: May 13, 2007, 04:58:25 PM »
Thanks, Ray.  I have some of that, but have never used it on an airplane!  Glad to know it will work for us.
Offline Rob Killick
« Reply #3 on: May 13, 2007, 05:44:59 PM »
Yessiree !
Thanks Ray
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #4 on: May 14, 2007, 06:19:54 AM »
Look on the can and see if it says anything about being Alcohol resistant after it's cured. I went to our local Home Depot and bought 5 or 6 cans of different brand polyurethane just to run some tests. The ones that stated they were resistant to Alcohol were all fuel proof, the ones that didn't weren't.
    • Minnesotamodeler
« Reply #5 on: May 14, 2007, 07:53:55 AM »
Useful bit of info...thanks, Bob.
--Ray
AMA902472
Offline Larry Wong
« Reply #6 on: May 14, 2007, 08:07:27 AM »
I've used Minwax and found it fuel proof , But it is vary hard finish tends to chip easy, and a lot of polishing to get the finish I wanted.  I have change to PPG automotive clear with less work and great finish and vary shiney...... #^ #^ #^ #^ #^ #^ #^ #^
Larry
