  • July 05, 2025, 05:48:26 PM
Author Topic: thick trailing edge  (Read 3025 times)
Offline Bootlegger
thick trailing edge
« on: September 25, 2015, 11:47:42 AM »
 Have some foam wings that have a 3/8" trailing edge and the  flaps will be 1/4".Will the difference make the model act/fly funny?
 I don't need to compound my problems.
        Thanks a lot... H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: thick trailing edge
« Reply #1 on: September 25, 2015, 11:56:49 AM »
The Impact has a 1/2 inch trailing edge,, and 3/8 flaps,,
I would say it might HELP  it fly better, not hurt it
Offline David Hoover
« Reply #2 on: September 25, 2015, 12:27:42 PM »
However, depending on the length of the flap, 1/4" may be a little wimpy in torsion and that would not make it fly better.
Best, Hoovie
« Reply #3 on: September 26, 2015, 06:46:35 AM »
For the 1/4" flap you could apply 1/2 oz fiberglass cloth with finishing resin (after wetting the cloth down scrape off as much as you can with a playing card then roll with toilet paper to remove last puddles). This gives very stiff flaps and is light weight. After that finish as normal.
Best,    DennisT
« Reply #4 on: September 26, 2015, 08:10:11 AM »
Best,    DennisT
Dennis,
That's a great way of doing it.
I used resin and glass cloth on these pieces. Sig Polyester resin actually, thin enough to apply with a brush then blot with toilet paper.
Today Epoxy is preferred and is a bit thicker so spreading it as Dennis suggested is how some do it.
These parts belong to the Mig-3.
Online Lauri Malila
« Reply #5 on: September 26, 2015, 10:37:05 AM »
...and not forgetting to put the cloth with fibers running +/-45 degrees, if you want torsional stiffness.
But the 1/2oz stuff is quite gutless, I'd go for at least twice as heavy. Weight gain is zero or minimal. L
« Reply #6 on: September 26, 2015, 10:46:08 AM »
Lauri,
I always uesd 3/4oz. I have so much of it. All our R/C pattern ships were covered in it from head to toe.
Offline Target
  • C/L Addict
« Reply #7 on: September 26, 2015, 10:55:09 AM »
If you're using cloth hinges, what I'd do is bond a same diameter aluminum tube to the LE of the flaps, then glass wrap in one piece on a 45° bias as mentioned with glass. Tubing is very torsional stiff.
R,
Chris
Chris
AMA 5956
