Building Tips and technical articles. => Building techniques => Topic started by: Bootlegger on September 25, 2015, 11:47:42 AM
Have some foam wings that have a 3/8" trailing edge and the flaps will be 1/4".Will the difference make the model act/fly funny?
I don't need to compound my problems.
Thanks a lot... H^^
The Impact has a 1/2 inch trailing edge,, and 3/8 flaps,,
I would say it might HELP it fly better, not hurt it
However, depending on the length of the flap, 1/4" may be a little wimpy in torsion and that would not make it fly better.
For the 1/4" flap you could apply 1/2 oz fiberglass cloth with finishing resin (after wetting the cloth down scrape off as much as you can with a playing card then roll with toilet paper to remove last puddles). This gives very stiff flaps and is light weight. After that finish as normal.
Best, DennisT
Best, DennisT
Dennis,
That's a great way of doing it.
I used resin and glass cloth on these pieces. Sig Polyester resin actually, thin enough to apply with a brush then blot with toilet paper.
Today Epoxy is preferred and is a bit thicker so spreading it as Dennis suggested is how some do it.
These parts belong to the Mig-3.
...and not forgetting to put the cloth with fibers running +/-45 degrees, if you want torsional stiffness.
But the 1/2oz stuff is quite gutless, I'd go for at least twice as heavy. Weight gain is zero or minimal. L
Lauri,
I always uesd 3/4oz. I have so much of it. All our R/C pattern ships were covered in it from head to toe.
If you're using cloth hinges, what I'd do is bond a same diameter aluminum tube to the LE of the flaps, then glass wrap in one piece on a 45° bias as mentioned with glass. Tubing is very torsional stiff.
R,
Chris
