  • June 18, 2025, 04:36:30 AM
Author Topic: Dope Substitute?  (Read 6238 times)
Offline Chancey Chorney
Dope Substitute?
« on: August 17, 2015, 08:24:03 PM »
Hi there.  I am just about at the finishing stage of a 1/2a control line airplane here and had a little question regarding the finishing of it.  I would also lik eto save weight so thought about a tissue paper covering for it to add just a bit of color.  So my question is about dope substitutes.  Mainly, MinWax Polyurethane clear varnish.  Has anyone tried it to seal a 1/2a plane and found it to be fuel proof?  It is a lot cheaper than dope, if I can even find any locally, as well as I would be able to use it on other things as well.  If not, I may do a test myself, but just thought I would see if there was anyone that has tried it.
Ps.  Plane is a 1/2a White Lightening, profile fuse, solid 1/8" flat wing.
Offline Phil Krankowski
Re: Dope Substitute?
« Reply #1 on: August 18, 2015, 06:38:49 AM »
As long as we are talking the stinky solvent based polyurethane and not any water based product, then it is fuel proof.  It come in aerosol cans too.
Phil
« Reply #2 on: August 18, 2015, 12:40:32 PM »
You could look at Rustoleum or equivalent. Cheap, comes in spray cans at the hardware store.
« Reply #3 on: August 18, 2015, 05:46:21 PM »
Great, thank you for the replies.  Yes, I have the stinky here.  So, I will probably attempt a tissue covering here in the near future.  I did find a bunch of stuff related to this online after I reworded my search as well.
Offline Dennis Saydak
« Reply #4 on: August 18, 2015, 07:01:42 PM »
Chauncey, even Butyrate dope isn't completely fuel proof if you are using a high-nitro content 1/2A fuel. I believe you have experience with 2 part automotive clear coats. Other than that an epoxy clear or polyurethane will do the trick.
« Reply #5 on: August 19, 2015, 08:24:59 PM »
Thanks Dennis.  Yes, I had experience with the automotive clear coat, I just miss working in a standard bodyshop where I had access to mass quantities at my disposal, as well as the paint.
« Reply #6 on: September 18, 2015, 06:00:06 PM »
Chauncey,
If you are using tissue to cover open bay areas then you need something that will shrink the covering tight, this is dope. If you are covering solid wood you can use the Poly or Rustolum but it will add more weight then the dope. For a fuel proof top coat you could look into KBS diamond clear (https://www.kbs-coatings.com/DiamondFinish-Clear.html). They have a small more cost effective (at least for our purpose) "Clear Coat Kit" look down the page.
Best,     DennisT
« Last Edit: September 18, 2015, 06:36:15 PM by Dennis Toth »
