  • June 21, 2025, 04:34:30 AM
Author Topic: Power Jig Saw fix!  (Read 903 times)
Offline Larry Renger
Power Jig Saw fix!
« on: September 02, 2010, 10:46:56 AM »
My Dremel Jig Saw has a huge hole where the blade goes through.  This is fine for changing blades, but lousy for cutting small parts.
Sooooo, I made a removable top plate, and end of problem!
Re: Power Jig Saw fix!
« Reply #1 on: September 02, 2010, 11:11:54 AM »
My jigsaw is a Delta. It has an insert around the blade that is removed to change blades. But the hole for the blade in it was quite large. I replaced in with an aluminum unit that has a much smaller pass for the blade and does make cutting small parts much easier.
Same idea, but different execution due to different jigsaw design.
Yours is a clever idea.
« Reply #2 on: September 25, 2010, 08:37:23 AM »
Mine is a Craftsman, and when I cut Mother Of Pearl for inlay work it tends to want to break the stuff, I'll build one of these and life will be MUCH better - thanks for the tip!!!!!!!!!!!!!!!!!!!!!!!! #^ #^ #^ y1
Will
