  • July 04, 2025, 10:11:33 PM
Author Topic: my intro to ca disasterous  (Read 2435 times)
ron young
« on: June 05, 2011, 04:03:41 PM »
   Hello
Well i am trying to put together BRODAK SUPER CLOWN ,backing up a little i am not a builder or even a reasonable mechanic type so in trying to install the elevater hinges with ca i have made them non operatable all 4 hinges solid as a rock no movement i have pulled and pulled trying to remove not working do you have any thoughts or do you think i will have to scrap them and start over.I have been actually trying to get into this sport for a couple seasons with little or no luck i know this isnt that tough but i am certainly trying to make it that way
Frustrated in Toledo
Ron
Offline Leester
Re: my intro to ca disasterous
« Reply #1 on: June 05, 2011, 04:44:27 PM »
Hey Ron, well as they say SH%t happens. I'm guessing your using the plastic hinges with a pin in the middle ?? If so try to cut the head of the pin off with some wire cutters and pull the pin out or use Debonder on them and see if they'll free up. I usually use epoxy (30 min.) that way you can clean the pin  with alcohol using a Q tip until the epoxy cures. As a last resort cut new Elevators and start again.
Good Luck and it does get easier.
Leester
ama 830538
« Reply #2 on: June 05, 2011, 07:20:50 PM »
As a second-to-last resort cut through the hinges, then either carefully slice them out of the structure and replace them, or just put new hinges in next to the ones you've got.
If there's a club nearby join it now.  Folks will want to see you flying, and will help you out.  With luck, you may even be able to buy someone's plane all ready to fly, or needing just an engine (i.e., a lot more 'almost ready to fly' than an ARF that you'd get from Brodaks).  Or, if you've got the pocketbook for it, buy and ARF and have someone assemble it for you.
« Reply #3 on: June 05, 2011, 07:25:01 PM »
Oh, and -- it could have been worse.  I thought from your subject line that this might be a story of you gluing your fingers up your nose, or your eyeballs to your eyelids, or some other painful, embarrassing and possibly maiming thing.
(We got to talking about debonder at one of the meetings of our RC club.  Our president admitted that he holds CA bottles to his ear and squeezes them to see if the tip is clogged.  Once when doing that he accidentally squirted a good bunch of glue up his ear.  Then, thinking a bit too quickly, he jammed his finger in his ear to try to get it out.  Me, I've just found myself glued to my work.  Literally.)
« Reply #4 on: June 05, 2011, 11:48:23 PM »
This file details about the only safe way to use CA on barrel-type hinges. Dipping the barrel in melted Vaseline is one of the key tricks. The silkspan is a brilliant idea. If your slots are too big, add a second layer of silkspan.
There's gotta be some help available in Ohio. Ask and ye shall receive.  y1 Steve
« Reply #5 on: June 06, 2011, 12:53:04 AM »
Your all overcomplating it.
Use Acetone, it will break down the glue.
« Reply #6 on: June 06, 2011, 01:09:05 AM »
I will further add to this :
Installing Pin style hinges properly:
Best way I found :
Fold the hinge in 1/ 2 and get a container lid - pour in some thin oil - after run oil or lubricating oil
Dip the barrel into the oil only - not the entire hinge, only the 1 mm barrel.
Use 5 minute epoxy - spred a VERY VERY VERY thin layer of epoxy over one side of the hinge.
Slide it into place 1 1/2 first - set the depth of the barrel to be level.
Let the 1 / 2 dry.
I usually wipe the oil away - then reapply with a little drop of oil into the barrel again -
repeat the process for installing the flap into the hinge.
This will result in free hinges that you cannot pull out .
« Reply #7 on: June 06, 2011, 04:09:36 PM »
Hi Ron,
What PJ said about the acetone is right on.  I can help you out if you want to drive out to Napoleon some time soon.  I even have the acetone on hand - just used some today for a different type of job so I know right where it is!  Also, I can show you the melted Vaseline trick, it's super good.
Will
Offline Peter Nevai
    • C3EL
« Reply #8 on: June 06, 2011, 05:35:26 PM »
Here is a trick that works and one I've used very often on barrel hinges. Somthing to remember for the future. Ths only works if you cover the elevator or flaps after assembly. Once you have made the hinge slots, insert the hinges and mount the elevator / flap. Next use a sharp drill bit that is a little bit smaller than a round toothpick, and caerfully drill a hole through the center of the hinge, right through the stab / wing trailing edge. Then coat round toothpics with a bit of epoxy and push them through the holes you made. Pinning the hinges with the toothpics. When the epoxy is dry, carefully trim off the toothpics close to the surface the sand smooth. This method eliminates any chance of getting glue in the hinge.
« Reply #9 on: June 06, 2011, 07:06:07 PM »
I would suggest you do a test hinge.
try putting on the SMALLEST possible amount of epoxy after dipping into the oil.
You will be amazed as to how little you need to get it to hold.. sometimes less than 1 eyedrop on one side will hold it.
Then try to pull out the test peice.
With each stunt ship having between 16 - 20 Hinges.. Ive done 4 in the last 12 months..  Thats alot of free hinges Ive put in.
There is also a post in building section I made to inform people on how to install hinges correctly.
http://stunthanger.com/smf/index.php?topic=21145.0
« Reply #10 on: June 07, 2011, 12:20:44 AM »
Don't put any glue on the hinge. Put the epoxy into the slot first, then slide the hinge in. No glue will squeegy out to the hinge barrel that way.
« Reply #11 on: June 07, 2011, 12:25:12 AM »
depends how thin you put it - I put it on VERY thin.. so thin nothing squeezes off. But either way is good advice.
ron young
« Reply #12 on: June 07, 2011, 04:46:36 AM »
    Thank You All
I appreciate all the good advice i believe i will take Mr Hinton up on his offer to help
Have a good day
Ron
« Reply #13 on: June 07, 2011, 10:33:17 AM »
    Thank You All
Have a good day
Ron
Most excellent choice!  y1 Steve
« Reply #14 on: June 09, 2011, 04:54:24 PM »
I believe that stab is only 1/8" thick. Cut of the hinges and sand the edge smooth and use cloth hinges. You will be all done in 30 minutes.
« Reply #15 on: June 10, 2011, 10:03:43 AM »
When you talk cloth hinges to a beginner, more info is necessary.  The best cloth hinge material is Rayon "taffeta", available at fabric stores.  A $1 worth will last you a long time!  Stick it down with Ambroid.
« Reply #16 on: June 10, 2011, 11:26:04 AM »
The other alternative is to use the "Monocoat Hinge" system.  These are super quick and easy to use.  A lot of info has been posted on the forum about them so a detailed explanation is readily available, if interested.
And Taking up Mr, Hinton is a GREAT idea!  Will is "top drawer", and will be a great help to you in trying to get started.  Really, get to know Will real well. (and ask him about the "Army Tent")  ;D
Big Bear
Online john e. holliday
« Reply #17 on: June 11, 2011, 08:48:08 AM »
Don't forget that Will is also a great author of western books.   I have all three books that I know about and am waiting for the next generation of the family that will be.    H^^
« Reply #18 on: June 11, 2011, 01:14:51 PM »
Thanks Bill & Doc, you're gonna make me expand my hat size if you keep this up!  Blessings.  (Next book will be a while yet, Doc, but I'm working on it.)
