Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 20, 2025, 03:27:09 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Power Jig Saw fix!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Power Jig Saw fix! (Read 901 times)
Larry Renger
21 supporter
Trade Count:
0
Admiral
Power Jig Saw fix!
on:
September 02, 2010, 10:46:56 AM »
My Dremel Jig Saw has a huge hole where the blade goes through. This is fine for changing blades, but lousy for cutting small parts.
Sooooo, I made a removable top plate, and end of problem!
Logged
BTW, Dracula Sucks! A closed mouth gathers no feet!
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Power Jig Saw fix!
Reply #1 on:
September 02, 2010, 11:11:54 AM »
My jigsaw is a Delta. It has an insert around the blade that is removed to change blades. But the hole for the blade in it was quite large. I replaced in with an aluminum unit that has a much smaller pass for the blade and does make cutting small parts much easier.
Same idea, but different execution due to different jigsaw design.
Yours is a clever idea.
Logged
Will Hinton
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
September 25, 2010, 08:37:23 AM »
Mine is a Craftsman, and when I cut Mother Of Pearl for inlay work it tends to want to break the stuff, I'll build one of these and life will be MUCH better - thanks for the tip!!!!!!!!!!!!!!!!!!!!!!!!
Will
Logged
John 5:24
www.fcmodelers.com
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Power Jig Saw fix!
