  • August 04, 2025, 05:37:31 AM
Author Topic: Looking for an Answer  (Read 1282 times)
Offline Jim Pollock
« on: March 18, 2010, 05:11:09 PM »
Hello,
I happen to have "Dixon's" copy of the large Gypsy plans.  I have a question about them.  They show the wing as having a 55" Span.  I always thought the span to be 56"  With 28.5 inches inboard and 27.5 Inches outboard.
What the plans show is 28" inboard and 27" Outboard.  Which way is correct?  I don't have a copy of the Magazine article to know which is correct.
Someone please help!
Jim Pollock   n~
Offline Balsa Butcher
  • High Desert Flier
Re: Looking for an Answer
« Reply #1 on: March 18, 2010, 11:13:47 PM »
Jim: I have the Gypsy 46 plans from Flying Models Magazine but not the article. Using my trusty measuring tape I measure the outboard wing at 27 1/2" and the inboard wing 28 1/2" for a total of 56". I would trust these plans more than the other ones you have as I believe Alan Brickhaus worked closely with Jim Silhavy on making them as accurate as possible.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: March 19, 2010, 12:44:09 AM »
Hey Pete, nice avatar pic!
Offline Jim Pollock
« Reply #3 on: March 19, 2010, 04:50:30 PM »
Thanks Pete,
That's what I thought it should be.  Now to adjust the plans I have to get the correct wingspan.
Jim Pollock,  I guess I should have known.......  VD~  n~
  • High Desert Flier
« Reply #4 on: March 20, 2010, 05:18:40 PM »
Yup Clint, I thought it would be an apprporiate time (March/VSC) to put that one up. Jim: hope you make the Gypsy, one of my favorites, If you get ribs lazar cut somewhere let me know, I'd like to have a set for future reference.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Jim Pollock
« Reply #5 on: March 23, 2010, 04:57:08 PM »
Well,
I have figured out what to do.  The Rib spacing is said to be 2 1/16".  I checked and 2 1/8" works out perfectly to a 28 1/2" inboard wing.  Just use the same spacing on the outboard wing and cut 1/2 of the last rib section out and wa-la you then have a 1 1/16" difference, good enough for make-up work!
Jim Pollock, yipee  y1
