  • June 20, 2025, 12:44:33 AM
Author Topic: Sandable glue  (Read 2067 times)
Offline John KruziK
Sandable glue
« on: October 31, 2009, 07:09:49 PM »
What type, or brand of glue is sandable when dry. Like for a cowl where multiple layers are bonded. Thanks John
AMA 874027
Re: Sandable glue
« Reply #1 on: October 31, 2009, 07:33:44 PM »
 I use Sig Sigment cement, or Duco cement. Both sand quite well. I build a lot of fuselage tops using the planking method, where 1/4" strips a glued together to form the top of the fuse over formers. I use 1/8" thick strips, and when sanded the joints disappear.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Sandable glue
« Reply #2 on: November 01, 2009, 01:27:23 AM »
Most any kind of yellow (not white) woodworker's glue.  Elmer's makes some, as well as Titebond, and many other brands.
--Ray
AMA902472
Offline Ward Van Duzer
Re: Sandable glue
« Reply #3 on: November 02, 2009, 07:54:12 AM »
Offline Wade Bognuda
Re: Sandable glue
« Reply #4 on: November 02, 2009, 09:39:31 AM »
Don't, it is a mistake. Any glue can be sanded. The issue is that if the glue is harder than the balsa, balsa will be removed on either side of the joint faster than the glue. Ambroid is excellent, an old standard that still works well to day. Not for internal joints, but for external joints that will be part of the finishing process.
    • Minnesotamodeler
Re: Sandable glue
« Reply #5 on: November 02, 2009, 10:17:15 AM »
Well, "any glue"can NOT be sanded...if you ever tried white Elmer's, it sort of softens from the friction and starts balling up, on the paper and on the joint.  I've been using yellow woodworkers' glue for several years for just about all my building.  An occasional epoxy joint, GOOP for canopies/etc., otherwise nothing else, internal and external alike.  I find no problems sanding/finishing it.
On the other hand, my finishes are not exactly what you'd call "front row"!--or even respectable by most modelers' standards: Minimal sanding, shrinky-dink the wings, a coat or 2 of primer on the fuse and tail, maybe 2 coats of color (maybe not), a little clear topcoat if it doesn't look shiny enough, and go fly!  So I suppose if you're looking for a really good finish you shouldn't do as I do...
--Ray
AMA902472
Re: Sandable glue
« Reply #6 on: November 02, 2009, 02:22:39 PM »
Yeah.
    • Minnesotamodeler
Re: Sandable glue
« Reply #7 on: November 02, 2009, 03:50:46 PM »
Glad you agree.
--Ray
AMA902472
Re: Sandable glue
« Reply #8 on: November 02, 2009, 09:32:35 PM »
We're just being honest.
    • Minnesotamodeler
Re: Sandable glue
« Reply #9 on: November 03, 2009, 03:10:01 PM »
Painfully.
--Ray
AMA902472
Re: Sandable glue
« Reply #10 on: November 04, 2009, 06:33:58 PM »
One trick that works well for sanding across glue lines is to use a wood rasp.  You can get them in various grades of coarse.  The rasp doesn't flex at all, so it cuts the glue(as long as it isn't rubbery like white glue) the same as it cuts the wood.  It will even cut hard spots or glue lines down to foam without undercutting on either side.
Offline John KruziK
Re: Sandable glue
« Reply #11 on: November 22, 2009, 01:29:35 PM »
Thanks any sourse for rasps? Local hobby shop deals in ARFs only.  John
AMA 874027
Re: Sandable glue
« Reply #12 on: November 22, 2009, 07:03:48 PM »
A good, old-fashioned hardware store, tool supply, wood working supply store(expensive), or online.
