Hey Gordon, my "Smokin" Bucaneer is being finished right now. As usual, all dope, light silkspan over wood 1/2' fiberglass on the nose applied with Z-poxy. Only CF is on the flaps, not necessary on a foam wing. Why smokin'?, it's got a pipe.
As far as your's goes, I'd contact the designer, Alan Brickhaus regarding his finishing technique. He uses plastic film on the wings and stab, rust oleum on the fuselage. His technique has been posted and published and works well.
My technique is old school however I've got away from nitrate but using rustoleum that would be a good base. A couple of coats of nitrate, apply light or med silkspan, a couple more coats of dope then switch to the rustoleum primer and paint ought to do it. Good Luck!
