  • July 03, 2025, 09:15:27 PM
Author Topic: Removable gear for an I beam wing.  (Read 1609 times)
Offline Pat
« on: March 08, 2013, 09:38:35 PM »
Some folks have recomended putting a removable gear on the next I beam wing I build. Can anyone give me an idea of how to do this? If I put a gear block on the spar (I beam) won't that interfear with the placement of the ribs and half ribs?
Pat
Offline RC Storick
Re: Removable gear for an I beam wing.
« Reply #1 on: April 07, 2013, 07:31:58 AM »
« Reply #2 on: April 09, 2013, 12:45:15 AM »
Pat
Pat,
See the pictures of my Collussus.  It has removable gear.
The gear blocks are epoxied to the I-beam and encased in 3/16 balsa with a removable top that holds the gear in place (balsa over plywood) by means of 4 4-40 cap screws into blind nuts on the back side of the gear blocks.
The ribs are then simply glued to the balsa part of the gear blocks.
