  • June 19, 2025, 09:41:34 AM
Author Topic: Motor pads ?  (Read 1364 times)
Offline Rob Killick
Motor pads ?
« on: April 07, 2013, 03:04:34 PM »
Hi ,
Newb question time  ...
I've installed 1/8" thick aluminum pads on the motor crutch (inverted motor mounting) and I was wondering if all I have to do is move the nose ring to accommodate the new spinner , back plate location ?
All I see different , is the motor center line (profile view) is 1/8" lower than the plan original , profile center line .
Will this cause any problems ?
Thanks ,
Rob K.
Rob Killick , MAAC 33300
Offline Paul Wood
Re: Motor pads ?
« Reply #1 on: April 08, 2013, 07:20:59 AM »
Rob,
I would be aware of the tank location in relation to the engine.  As far as vertical CG and flight performance, I wouldn't think the difference would be noticed.
Re: Motor pads ?
« Reply #2 on: April 08, 2013, 08:39:50 AM »
I've never put pads in a full-fuselage model (I haven't built more than one!!).  I'd keep the engine in the same place in the plane, though, either by relieving the bearers where the pads go, or moving the bearers up.
Taking a spin through as many build threads as you can find in "Building Techniques" and seeing what was done should give you some ideas.
Online Doug Moon
Re: Motor pads ?
« Reply #3 on: April 08, 2013, 02:08:16 PM »
what plane is it?
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Rob Killick
Re: Motor pads ?
« Reply #4 on: April 08, 2013, 03:08:05 PM »
For Doug's question  ...
The  model is C. A. Mackey's Blue Bird . with a Brodak .25 for power .
Tim ,
The aluminum pads  aren't adhered to the  maple mounts , other than the mounting bolts and engine lugs , holding them to the maple .
Thanks for viewing my post ,
Rob K.
Online Doug Moon
Re: Motor pads ?
« Reply #5 on: April 08, 2013, 03:44:40 PM »
If it is not an in line design I would be tempted to just roll with it.  Make the adjustment to the nose ring.  Make sure there is enough room to adjust the tank down another 1/8 that you have lowered the motor.  1/8" is probably not noticeable.
At the same time maple beams are plenty hard enough to handle a .25 without much crushing.
Its your choice but I don't think you run into problems either way.
Doug Moon
AMA 496454
Offline Rob Killick
Re: Motor pads ?
« Reply #6 on: April 08, 2013, 05:41:42 PM »
Gentlemen ...
I think I will go with the plain maple mounts and build as per plan . Maybe with more searches , I can get a better idea of what should be done to te front end of my future models . y1
Thank you very much ,
Rob K.
