  • July 08, 2025, 10:23:49 PM
Author Topic: Building another one  (Read 34307 times)
Offline Doug Moon
Re: Building another one
« Reply #50 on: January 16, 2013, 11:30:29 PM »
Flap continued.
1. I strip and start laying in 1/16 ribs.
2. Finished the ribs.
3. Final Sheeting is added and the weight looks good.
At this stage the flap is more flexible than it will be once it is doped and covered with polyspan.  At that point it becomes very stout.  The hings slots are build into the LE and the reliefs for the hinge barrels are sanded in.
The outboard flap will be built in the same manner.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline MarcusCordeiro
« Reply #51 on: January 17, 2013, 05:40:06 AM »
That's very nice!!
Doug, do you round the TE edges or leave them square?
really looking forward to seeing this ship ready!!
Thanks for sharing.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Doug Moon
« Reply #52 on: January 17, 2013, 09:11:13 AM »
That's very nice!!
Thanks for sharing.
Marcus
I round off the TE.  I have heard that squared off will perform better but I do round them off.
Doug Moon
AMA 496454
Offline Duke.Johnson
« Reply #53 on: January 17, 2013, 09:21:54 AM »
Doug
I like the idea of make your own adjustable lead out guide as you did.  My son has one on a carrier plane, but its exposed.  The one you built looks really nice, but what do you use as an insert?  I guess I'm assuming you have an insert that you pull out of the lead out hole and move to a new hole.
Duke
« Reply #54 on: January 17, 2013, 01:47:26 PM »
That's why I asked... Have heard the same.
Thanks Doug
Marcus
Aces High!
Offline Doug Moon
« Reply #55 on: January 17, 2013, 02:44:26 PM »
Duke,
I will get a pic for you tonight showing what I use.
Marcus,
If I had them squared off I know I would get dents in the sharp edges so I just round them off.  I wonder how much a difference it really is?
I know I can tell tapered vs non tapered.  Non tapered is more effective.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #56 on: January 17, 2013, 08:34:07 PM »
Here is a close up of how I move the line then anchor the position.
Each of the holes in the slider are threaded with a 4/40 tap.  Then I use my drill press and vice to hold a 4/40 nylon screw and drill a hole lengthwise through the screw.  Usually about 3/8" is as far as it goes before the bit walks out of one of the side of the screw.  But 3/8" is plenty. Then I pass the LO through the screw and put in place.  If I need to move unscrew and slide front to back.  Then tighten and go fly.
One of the very last things I do before the first flight is add one drop of silicone based chain lube to the LO at the screw and it will be slick as long as you regularly fly it.  I have never had them get stiff or not move freely, even after 1500 plus flights over 8 season.
That pic is taken with my phone.  Then cropped and zoomed on my phone.  Amazing and so simple.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #57 on: January 17, 2013, 09:07:09 PM »
LiPo batteries and charger finally came in.  Now its on a full brushless system from Castle Creations.  The ESC is cool it has a tiny cooling fan on top.  You can hear it running with the car is sitting still.
This things hauls ass!  Now I can really break something!
Doug Moon
AMA 496454
Online wwwarbird
« Reply #58 on: January 17, 2013, 09:58:58 PM »
Flaps.
Yesterday I built the inboard flap.
I use built up flaps 5/16" thick with no taper.
1. Layout the parts.  I use 1/16" balsa to cut the sheeting.  I strip out 1/16" as well the width of the hinge I will be using, and strip some 1/8" as well.
2. Laying out the flap frame.  I build with CA so it is important to keep everything flat on the surface at all times or it will warp as I apply CA during the build. That is why you see the glue bottles laying along the edge.  I have also used thick CA and tack glued it to the bench as well in several areas around the edge. That option actually works the best.  I keep it up against a straight edge as I work as well. I lay down the 1/8 frame around the outer edge of the sheeting.
 Not that it matters, but doesn't this actually add up to a 1/4" thick flap and not 5/16"?
Offline Doug Moon
« Reply #59 on: January 17, 2013, 10:25:58 PM »
Yeah its 1/4 plus the 1/32 insert for the hinge slots.  Its not quite a full 5/16 but just a tad more than 1/4.  But it is consistent all the way through. on both flaps.
Doug Moon
AMA 496454
« Reply #60 on: January 18, 2013, 08:20:55 AM »
Hey Doug have you tried freezing the nylon screws before drilling them?   I have even used shorter drill bits that have a tendency to wander while drilling.
Offline Doug Moon
« Reply #61 on: January 21, 2013, 11:45:24 PM »
Here is the wing complete minus the flap horn.  Span is 63".  What you see here weighs 11 oz.  Not super light but should be in the ballpark.
Doug Moon
AMA 496454
« Reply #62 on: January 22, 2013, 02:51:59 AM »
Doug
Looks great!!
What covering are you using?
Marcus
Aces High!
« Reply #63 on: January 22, 2013, 04:53:07 AM »
You suck. That thing is going to kick ass in the Lee's parking lot races.
Derek
Offline Doug Moon
« Reply #64 on: January 22, 2013, 07:17:23 AM »
I am going to use polyspan for the open bays and either carbon veil on the wood areas.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #65 on: January 23, 2013, 07:23:16 AM »
Derek
I already broke part of the front suspension.  It's fixed up though.  It's almost uncontrollable.   :) :) :) :) :)
Doug Moon
AMA 496454
« Reply #66 on: January 23, 2013, 09:07:35 AM »
There's a guy who used to bring his RC off road car to use the jumps at our local BMX place. He could do backflips with the car, when it survived...
I like RC off roaders, but with IC, the noise you know... I might get one soon. Have a student who has one but doesn't use it.
Maybe I can trade it for some better grades... LL~ LL~ LL~ LL~
Marcus
Aces High!
Offline Doug Moon
« Reply #67 on: January 28, 2013, 11:54:00 PM »
Back in the shop over the past few days and I built the stab.  For some reason I really enjoy building the stab.  I know once you have read this you will think there is are alot of easier ways to get the same result.  But, for me, I like to build this structure even though I am sure it is over built.  I have an old one that has a large crack in it that can't be used.  I keep it around as a template, you can see it in the first few pics.  I sure makes it nice when there is no plan available to have a part to work from.
I use a flat stab just over 1/2" thick.  Rounded LE and TE.  The span is 29", 4 1/2" root and 2 1/2" tip chord.  As with the main wing the stab LE shape must be consistent.  I mold the LE out of 1/16" balsa. I use a brass tube attached to a piece of wood.  Then wet and wrap as normal. Once the mold has dried I sand a trim the piece from the mold buck.  When removing the piece it can tend to curve up a bit.  Then I attach it to a piece of 3/32" or 1/8" balsa as a backing piece to keep it straight.  I attach the backing piece to the table while attaching the mold to it making sure it stays in place until the CA has fully cured.  This will insure it stays straight.
Next I build the trailing edge.  I like to build in the hinge slots as I build the TE.  I start by attaching the straight edge to the table.  Then I attach a piece of 1/4" balsa to the table against the straight edge.  Then I glue on pieces 1/32" balsa leaving gaps for the hinges.  Next pass over the 1/32" balsa with a sanding block to make sure they are same thickness as the hinges.  Then glue down another piece of 1/4" balsa.  The TE is complete.
Next I layout the LE pieces and complete the frame.  From there I trace and cut the center section sheeting for the top and bottom.  Next I have to install the ribs in the sheeted area.  From there I install what will be cap strips along the top prior to the ribs.  I put them in first so I can get them nice flat against the upper edge.  Then I flip it over for the rib install and the last of the cap strips.  Trim the edges and clean up any rough edges.  Next, round the TE.
It's all finished up.  The weight is good.
Just for grins I went back and counted the number of pieces used to make this thing, 96.  Yes, it's true, I am near the edge of insanity.  n~ n~ n~
The stab went together pretty much as planned.  The elevators are a different story.  I worked for several hours on Sunday and 3 attempts yielded WAY less than desirable results and alot of wasted time and balsa.  I day or two off is in order to come back with a clear mind and get them built correctly.
« Last Edit: January 29, 2013, 12:13:57 AM by Doug Moon »
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #68 on: January 29, 2013, 12:01:49 AM »
Continued
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #69 on: January 29, 2013, 12:02:57 AM »
The finished product.
Doug Moon
AMA 496454
« Reply #70 on: January 29, 2013, 01:57:58 AM »
Thanks for sharing Doug
That's nice!
Marcus
Aces High!
Offline Steve Thornton
« Reply #71 on: February 05, 2013, 11:08:40 AM »
Beautiful work Doug.  What type of glue are you using for the stab and the wing?
Steve Thornton
"Most of us won't make it out of this world alive."
Steve Thornton
Offline Doug Moon
« Reply #72 on: February 05, 2013, 02:09:44 PM »
Steve Thornton
Hello Steve,
I use primarily thin and medium CA on the wing, stab, elevators, top and bottom blocks.
Where epoxy is needed, bell crank mount etc.., I use 5 minute.
At the wing joint I have used 5 minute with milled fiberglass mixed in with great results for many years.  Where the pipe exits I use Proset epoxy over 6 oz. carbon in that area of the tunnel.
« Last Edit: February 05, 2013, 03:15:03 PM by Doug Moon »
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #73 on: February 07, 2013, 11:38:10 PM »
A little more progress.
I finished up the elevators.  I build the leading edge like the trailing edge of the stab matching the hinge slots.
The trailing edge of the elevators is laminated 1/8" balsa, 1/32" carbon blade spar, 1/8" balsa.  This makes it very stiff and still it very light weight.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #74 on: February 07, 2013, 11:39:10 PM »
Continued,
Doug Moon
AMA 496454
« Reply #75 on: February 08, 2013, 03:42:51 AM »
Great job!
Do you cover or sheet the stab/elev??
Marcus
Aces High!
Offline Doug Moon
« Reply #76 on: February 08, 2013, 07:52:39 AM »
I cover the stab/elev with Polyspan and Sig Nitrate dope.
Doug Moon
AMA 496454
Offline Paul Walker
« Reply #77 on: February 18, 2013, 08:37:44 PM »
Doug....Go to the Team Trials this year....You will do well in Poland!  The US team needs you!
PLEASE consider this....PLEASE.
« Reply #78 on: February 18, 2013, 10:30:58 PM »
Thanks Doug, I really like this idea.
« Reply #79 on: February 19, 2013, 12:29:27 PM »
We have discussed this a time or two. I plan on flying at the TT this year instead of running it.
Derek
Offline Paul Walker
« Reply #80 on: February 19, 2013, 08:41:46 PM »
Derek
I thought you were going to sit out for one more year.  That's good to hear.
Have you built a new take apart plane yet?
And Doug, you should really consider the TT's.
Offline Mike Keville
« Reply #81 on: February 19, 2013, 08:48:09 PM »
Doug and Derek:
You could hardly find a better endorsement than one from PW.
Go for it!
Offline Doug Moon
« Reply #82 on: February 19, 2013, 10:29:20 PM »
Thanks for the vote of confidence!!  I will certainly think about it this year for sure.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #83 on: February 19, 2013, 11:14:28 PM »
Built the crutch.
Start with 1/2x3/8 maple beams.
Relieve 1/4" in the tank section of the crutch.
Cut out F1 and F2 from 1/8 hard plywood.  I would use 1/16 for F2 on a 65 plane but this is a 75 so I decided to stay with the 1/8 for both.
Using 1/16 balsa trace and cut out three pieces that fit the gap between the beams after initial installation. Laminate with medium CA
Install with epoxy between the beams making sure they are even with the top of the beams.
Cut from 1/8 balsa a filler that spans the area between the to of F1 and F2
Epoxy in place and clamp until dry.
Trim and sand the top piece until it is flush with the top of F1 and F2 and on the sides of the beams.
With the top filler piece in place it ties the beams together across the filler pieces.  It also creates a nice platform for the crutch to stand on upside down when installing the fuse sides to the crutch.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #84 on: February 19, 2013, 11:17:23 PM »
Continued
Doug Moon
AMA 496454
« Reply #85 on: February 20, 2013, 04:26:28 AM »
No I spent all my extra time building a non take-apart plane to save weight. I am happy with the new one it is MUCH lighter than the Matrix. If I were to make the team I would probably build another one but i still have the Dreadnought that flies really well.
Derek
« Reply #86 on: February 20, 2013, 05:32:33 AM »
A naive question...
The 1/4 relieved from the mounts is for adjusting the tank, isn't it??
Marcus
Aces High!
Offline Doug Moon
« Reply #87 on: February 20, 2013, 08:40:14 AM »
A naive question...
Marcus
Yes, the plastic 8oz tank will need some room to move up to get the right setting.
Doug Moon
AMA 496454
Offline Steve Fitton
« Reply #88 on: February 20, 2013, 06:24:04 PM »
The dremel must have been smokin' grinding all that wood away on the motor mounts!
Whats the deciding factor in the width of your crutch, the width of that 8 oz tank or the width of the 75?
Offline Doug Moon
« Reply #89 on: February 20, 2013, 06:30:27 PM »
Built the fuse.
1/8 48x4 balsa for the sides
Cut out needed slots for cowl, wing, and stab per numbers on the sheet
added 1/32 plywood doublers that extend past the wing
Glue the sides to the crutch
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #90 on: February 20, 2013, 08:12:22 PM »
Fuse continued
Add in filler pieces to keep the proper width top and bottom.
I dont start the taper until just after the TE of the wing.  I use a straight taper as well.  This makes it easy to keep it all straight.
I dont have one of those really cool fuse jigs. With the help of some RC construction techniques I have come up with a cool way to build the back half of the fuse with the taper and keep it even.  I measure the distance from where the taper starts, just about even with the TE of the wing, to the back of the fuse.  Then I measure the distance across the fuse at the last filler piece and across at the back of the fuse.  I usually have it only 1/8" wide at the back.
Then I cut 1/16 balsa in the shape of a triangle using those measurements.  From there I flip the fuse upside down and tack glue it to the last cross piece at the start of the taper.  I gently pull the two together and tack glue, using thin CA, the fuse sides every couple of inches to the triangle piece as I work my way to the back of the fuse.  It is VERY important that I squeeze them together at the same time.  If I dont it will pull it out of shape and the taper will not be even all the way back.  Once I have tacked it all the way back and I am satisfied with the taper and all is even I go ahead and glue the whole seam on both sides.
Then I flip it over and measure the distance across the fuse inside to inside at 4 separate stations between the trailing edge and stab leading edge.  Using a square I mark along the bottom of the fuse at the same spot the I measured at the top.  Next I cut 4 1/8x1/4 pieces of balsa per those measurements.  At the same stations along the bottom I pull the fuse sides together and install the balsa pieces.  I did drop the balsa pieces 1" into the fuse so I will have room for a pipe floor. Next I glue in some vertical balsa and balsa across the inside of the triangle taper piece.  These are my "window frame" formers.  Just for added support I go ahead and add some cross bracing.  This area will eventually get a pipe floor very tightly fit inside the fuse sides.
I do not go back and remove that piece of 1/16 balsa that created the taper.  That stays in place.  Along with the pipe floor the back section is a box, very strong and twist resistant.  Then the 3/32 molded top and bottom blocks are added creating just that much more support.
Using some 1/32 ply I create some access hatches just below the stab TE.  These will come in handy should I need to change the push rod length.  Usually I end up adding in some down elevator.  These hatches make it a snap.
Now I add the tank floor.  I use a 1/16 hard plywood installed with 5 minute epoxy mixed with milled fiberglass.  The added milled fiberglass makes for some tough glue joints.  Once the tank floor is added the front half of the fuse is now a box as well.
If you noticed I kept the motor mount beams full length.  I install the nose ring right onto the end of the motor mount beams.  I also tie those motor mount beams into the top of the wing once it is installed.  I am certain I am overbuilding in some areas but I have found this method to yield a really strong fuse that will resist twisting and give good support to the motor to help create a good solid engine run.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #91 on: February 20, 2013, 08:19:48 PM »
Continued
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #92 on: February 20, 2013, 08:38:25 PM »
Here is the list now.  Making some headway.
On the fuse all I lack is the nose ring install and then initial nose shaping prior to putting in the wing.
During the fuse build I was able to get three coats of 50/50 Sig Nitrate dope on the wing/flaps stab/elevators.  I will cover those soon.  I like to cover them prior to going into the fuse.
Doug Moon
AMA 496454
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #93 on: February 21, 2013, 07:33:01 AM »
Is the Chevy truck on your workbench for hauling around the particularly
heavy pieces of balsa?
Later
Offline Doug Moon
« Reply #94 on: February 21, 2013, 08:13:48 AM »
Later
HAHAHAHAHA!!  I was wondering if anyone would notice that truck on the bench. Max has many of those hot wheels. i think it's a cool one and somehow it ended up on the bench.  It has a sport bike in the bed. So I just keep it up there.  Who knows where else it will end up next.
Doug Moon
AMA 496454
Offline Doug Moon
« Reply #95 on: February 21, 2013, 08:20:17 AM »
I have done it with the dremel before and it is a beating of the highest order. But now I just use the band saw and it makes quick work of that task.
On this model the width is driven by the tank. I have made them wider in the past and its nice to be able to slant the tank outward for a cleaner shut off.  But on this one I just copied the same as the nats plane. The 75 fits in there nice and snug.
Doug Moon
AMA 496454
Offline Mike Ferguson
« Reply #96 on: February 21, 2013, 03:50:59 PM »
Just wanted to thank you a lot for making this thread, Doug. I'm learning a lot from it.  :)
Offline Doug Moon
« Reply #97 on: March 05, 2013, 11:53:40 PM »
Hello,
I may have been away from here but I have been living in the shop.
I have made some progress.
I like to cover the wing and stab prior to installation into the fuse.  I also cover the flaps and elevators at this time.
I use poly span.  The surfaces are all covered with 3 coats of 50/50 sig nitrate.  Sanding the last one only.
Next I use about 90% thinner 10% dope mix to apply the ploy span.  I apply the thinner mix to the edges of the surface only leaving the middle area dry.
While one wing panel is drying I do the same thing to the adjacent panel.  Once I am sure it is dry I bring out the heat gun and shrink out the poly span.  You be surprised how much it will shrink and how it will pull out some pretty big wrinkles with ease.  BUT if I shrink it before that thinner edge area is really dry the covering will slip inward and wrinkle and will not be able to be straightened back out.  This happened to me on the outboard wing top side of course.  I went forward and applied thinner mic over the whole panel thinking I could work it back out and get it straight.  The slip was too much and it just wouldnt correct itself.  No worries though.  At this point since it has been attached with mostly thinner I just wet it again with thinner mix and it easily lifts off the panel.  I let it dry out over night and redo that panel the next day with no issues.  I cover the flaps elevators and stab in the same method.  My thought here is that if all the flying surfaces are prepped with the same covering it is that much easier to get a good consistent base for finishing.  It has been working out so far.
Once they are shrunk and covered once completely with thinner mix I let them dry for about 2 days.  Then I start with mix of 60% dope 40% thinner.  I go for 3 coats.  I only sand after the last one and I work the edges first.  If I have enough dope in the poly span the excess with flake off just like SS does.  From there with a used piece of 320 I lightly sand out all the surfaces and the wing.  I am careful not to grind on it.  I am simply knocking down the dope fuzz.  Poly span is not SS or CFV, it is not designed as a filling covering you can sand down flat. When you cut it with sand paper you weaken it and cause the polyester to fuzz up.  The fuzzies can be a nightmare.  But a drop or two of thin CA or a couple more coats of dope and you can lightly sand them away.  Dope will build up on top of the poly span as you go. After 3 coats of the above mix the lightly sanded surfaces are already feeling very uniform and will fill very easily with dope and zinc and final blocking coat of primer.
Next I built a balsa rack to store my wood.  I have been meaning to do this for some time, 6 years!
I also took a queue from Derek's finishing thread and built some much needed jigs for my flying surfaces.  I used 1x2 and ripped it on my table saw then ran a bolt through them with a wing nut.  Now I can keep flaps and elevators on there and they will stay straight while applying dope and paint.  Thanks Derek and Eric V for the tips.
Now I am getting ready to install the wing.  First thing I do is add alot of support braces in the bottom area that will be cut out and in the areas around them that wont be cut.  Its like chopping a car, you need something to keep things straight when you go to cut out a mian part of the structure.  Next I cut out the bottom on my band saw and start the initial fits.
Doug Moon
AMA 496454
« Reply #98 on: March 06, 2013, 10:02:06 AM »
Thanks for the pics and the reasoning.  Learn something everyday.
« Reply #99 on: March 06, 2013, 10:35:28 AM »
Man that is a great idea on the control surface jigs,,
I took a peice of particle board, slit a groove in it, and CA my brass tabs into the slit,, but well its only good for ONE airplane,,
I see a project on my horizon
