  • June 18, 2025, 06:39:06 PM
Author Topic: Interesting new possible flying line  (Read 1027 times)
Offline Larry Renger
« on: May 04, 2012, 08:54:01 PM »
This is some new stuff I am trying out.  It is not monofiliment, it is supposed to be made up of multiple (hundred+) strands fused together.  It is very thin, very slick, and has minimal stretch.  I have flown on it a couple of times, and will keep everyone posted on how it works out.  It is available in 1,2,3,4,8,10 and 12 lb test.  I am flying on the 8 lb, and its diameter is .006"!
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Interesting new possible flying line
« Reply #1 on: May 05, 2012, 10:15:38 AM »
Cost?
--Ray
AMA902472
Offline John Rist
« Reply #2 on: May 05, 2012, 02:46:40 PM »
Pull test on the knot?
« Reply #3 on: May 05, 2012, 03:23:25 PM »
I have "knot" pull tested the stuff.  I guess I should.  I did pull test the set of lines on the plane.  All went fine.
As I recall that 300 yard spool was $20.
