Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 02, 2025, 06:10:22 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
1/2 A building.
(Moderator:
Joey Mathison 9806
Whazzat?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Whazzat? (Read 1422 times)
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Whazzat?
on:
May 20, 2010, 12:25:40 PM »
From the bucket-o-engines. Looks McCoyish, but that crankcase?!?
So -- anyone know what it is? Good for parts? Good engine, if I can mount it? How is that venturi held in?
Logged
kenneth cook
Trade Count:
0
Admiral
Re: Whazzat?
Reply #1 on:
May 20, 2010, 02:24:39 PM »
Tim, thats a Testor's engine from the ready to fly plastic models that really never flew. The venturi is press fit in to the back of the case. Give it a good pull and a wiggle and there you will find the reed. Those engines were made in the cast metal and also plastic which was like a reinforced nylon. I did have a few that ran and the crank usually departed first. Ken
Logged
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Re: Whazzat?
Reply #2 on:
May 20, 2010, 02:50:50 PM »
It seems to have a good cylinder/piston fit -- I'm thinking that if the cylinder fits my other Testors engines I make just keep it for parts.
Or maybe I'll go to the trouble of making a plywood saddle for it, and go fly it.
So they really made those with plastic crankcases? Jeesh -- how cheap can you get?
Logged
philip metzner
chevyiron420
Trade Count:
0
Lieutenant
Re: Whazzat?
Reply #3 on:
May 20, 2010, 04:59:30 PM »
Tim, the glow head, starter parts, needle valve assembly, cylinder \piston will fit your wen-mac mccoy.
Logged
George
Trade Count:
0
Admiral
Love people, Use things.
Re: Whazzat?
Reply #4 on:
May 20, 2010, 05:58:42 PM »
My "product engine" with metal crankcase was in a space ship looking plane. Here is the standalone Testors 8000 with the "plastic" crankcase. They came with the cylinder mounted to the side.
George
Logged
George Bain
AMA 23454
Victor Jeffreys
Trade Count:
0
Lieutenant
Re: Whazzat?
Reply #5 on:
May 30, 2010, 06:34:47 PM »
For those with the machine shop and engine design skills, it might be possible to redesign crankshaft timing and fuel intake opening using the solid crankshaft and then put it into a FRV Wen-McCoy block.
Logged
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Re: Whazzat?
Reply #6 on:
May 30, 2010, 08:23:02 PM »
There's an engine design -- the Schroeder "Simple Single" -- out there that uses a Cox cylinder, piston and rod, and goes into a custom crank case with crank, etc. One could probably adapt it to this one.
http://www.modelenginenews.org/rsch/images/sst-2.jpg
No reason it couldn't be glow.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
1/2 A building.
(Moderator:
Joey Mathison 9806
Whazzat?
Jump to:
=> 1/2 A building.
