  • June 19, 2025, 06:21:14 AM
Author Topic: ??? what fuel???  (Read 1204 times)
Offline Bootlegger
??? what fuel???
« on: May 14, 2012, 08:08:46 AM »
   y1   Guy's what fuel are y'all runnin in the wasp 061, also what prop and R P M??  Thanks a lot... #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Larry Renger
Re: ??? what fuel???
« Reply #1 on: May 14, 2012, 11:27:38 AM »
10-10-10, 5.5x2.5 APC about 19K on the ground.  Holuszko venturi, Merlin glow-button.
Offline Bootlegger
« Reply #2 on: May 14, 2012, 12:37:56 PM »
    #^   Thanks Larry...'ppreciate it the info... #^
Gil Causey
AMA# 6964
Offline Andrew Tinsley
« Reply #3 on: May 14, 2012, 02:49:21 PM »
Hello Larry,
That is about what I use. I must admit that I can't really get used to the way the Wasp runs, fueled and propped that way. I have been flying small stunters from the 60s and they were designed mainly for a good 1.5 cc diesel. I just can't get used to such a small prop and high revs! I keep getting the feeling that the nose of these stunters are blanking out some of the airflow from such a small prop!
Proof of the pudding says that I am wrong and the models fly better than I can. Just shows how ingrained habits can be wrong!
Andrew.
BMFA Number 64862
« Reply #4 on: May 14, 2012, 10:30:20 PM »
It took me a couple of years to transition from standard Cox type engines to Norvel/AP type, and a few smashed models and a lot of frustration.  Start with my recommendations, THEN do your own thing.  The two types of engines run VERY differently, and certainly WAY different from a diseasled engine (which I love to run, also).  ;D
