  • June 16, 2025, 10:53:21 AM
Author Topic: Single channel use  (Read 14923 times)
Offline Vincent Corwell
Single channel use
« on: May 18, 2007, 04:19:40 AM »
Can you show a complete set up please for
a single channel, say for throttle control
servo , battery , controller unit
 at the handle end , battery? controller
Is it viable to use only one insulated line and one standard line?
Is there a link to your web site please ?
Thank you
Vincent
Offline Clancy Arnold
Re: Single channel use
« Reply #1 on: May 19, 2007, 09:25:24 AM »
Vincent
Check your Email.  I sent you a copy of the Single Channel U/Tronics Instruction sheet.  Hope that answers your questions.
The use of one insulated and one uninsulated line would work, but I would worry about the different air drag because of the different outside diameters.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #2 on: May 15, 2011, 03:42:08 PM »
Please note that the street address on the above drawing has changed.
Clancy Arnold
7174 Eagle Cove S. Dr.
Indianapolis, IN 46254
Clancy Arnold
U/Tronics Control
« Reply #3 on: May 15, 2011, 04:08:12 PM »
I recall a post here from someone who had just that problem -- one thin line and one thick line, and an elevator that responded in a consistent (and unfortunate!) manner to changes in line tension.
Offline John Rist
« Reply #4 on: May 31, 2011, 01:51:57 AM »
DO NOT USE ONE INSULATED LINE - unless perhaps you are coating your own lines with polyurethane. Even in that case I would coat both.  See post
http://stunthanger.com/smf/index.php?topic=18806.0
I lost my Eindecker due to one insulated line.  When I slowed down and line tension got low the drag on the insulated up line drove the Eindecker up and over the top - BIG SPLAT!
