  • June 15, 2025, 09:58:32 PM
Author Topic: Igor's Logarithmic Flap Setup  (Read 2692 times)
Offline jfv
« on: January 31, 2020, 05:12:32 PM »
Considering using Igor’s Logarithmic flap setup on my new plane.  Wondering regarding anyone’s experience with the setup.
Jim Vigani
Re: Igor's Logarithmic Flap Setup
« Reply #1 on: February 01, 2020, 01:59:04 AM »
I use it.  Works a treat.  Did I send you my control geometry program?
Offline jfv
« Reply #2 on: February 01, 2020, 03:15:15 AM »
No you never sent the program.  I would appreciate a copy.
Does it have to be lubricated? The linkage that is, not the program.
Jim Vigani
« Reply #3 on: February 02, 2020, 03:27:43 PM »
Thank you for clarifying the question.  My wife wouldn't have done so. She has decided that English has too many nouns to remember, so now she only uses pronouns or a universal substitute, "whatchmacall".  Worse yet, she uses masculine and feminine gender pronouns interchangeably.
I think the linkage should be lubricated.  Here is my attempt to lubricate it: https://stunthanger.com/smf/open-forum/abusing-medical-technology-to-oil-soak-the-inside-of-my-airplane/msg535214/#msg535214 .  Next time I may use some Igus slippery stuff instead of a ball bearing for the slider.
I hadn't considered lubricating the program, but now that you mention it, noise that I thought was coming from too coarse an iteration may be due to lack of lubrication.
