  • July 04, 2025, 04:42:01 AM
Author Topic: Flap thickness  (Read 2473 times)
Online Paul Allen
Flap thickness
« on: November 19, 2019, 01:47:02 AM »
Hi,is there any issue having the flaps slightly thicker then the trailing edge.
Thanks.
Offline Brent Williams
Re: Flap thickness
« Reply #1 on: November 19, 2019, 11:42:41 AM »
David Fitzgerald has that arrangement on his Thundergazer.
I don't think it has handicapped him very much....
Re: Flap thickness
« Reply #2 on: November 19, 2019, 12:10:13 PM »
Assuming we are talking about the wing TE and not the flap, this is really good news for my 2020 ship..  I went from a standard DuBro type hinge to a Roberts imbeded flap and in doing so I made the new flaps about 1/32 larger than the TE and didn't actually notice it till I was mounting them for the pre-finish test flights.  I was expecting some weird behavior but got none.  I guess it is not a good thing but it also might not be a bad thing either.
Re: Flap thickness
« Reply #3 on: November 19, 2019, 12:55:42 PM »
You are correct Ken, the trailing edge thickness on David's wing is slightly smaller that his flap leading edge thickness.  I had read about it previously so I made sure to look at it while he passed through Utah last July.  When I asked him about the reason for the difference, he laughed and said it is simply because that is the way the lost foam cradles arrived from Bob Hunt.   It was fun to spend some time looking over his plane in detail.
« Last Edit: November 19, 2019, 11:34:01 PM by Brent Williams »
Online Paul Allen
Re: Flap thickness
« Reply #4 on: November 19, 2019, 02:59:38 PM »
Thanks for the replies,I made the flaps built up, then when I shaped them I was a
little worried about how thin the trailing edge was,so I decided to sheet them,which made
them slightly thicker,then the wing trailing edge.
