  • June 15, 2025, 09:20:58 PM
Author Topic: Bellcrank and Control Horn ratios  (Read 6510 times)
Offline Douglas Ames
« on: January 30, 2015, 02:33:25 PM »
So here I am building a SIG/ Blackhawk Fokker DVII and I cut down a Perfect 3" BC (control horn) tab to the 5/8" position for clearance.
That's a ratio of 4.8:1.
Do I use 5/8" (.625") as a basis for the elavator pushrod position,or is there some formula? (bellcrank width vs. throw)
All these years I've just winged it and adjusted the throw at the horn. Is it that simple?
As you can see we have our choices...
AMA 656546
Re: Bellcrank and Control Horn ratios
« Reply #1 on: January 30, 2015, 03:15:29 PM »
There's a formula.  You got Excel?
If you're not doing stunts, adjusting the throw at the control horn should do the trick.
« Reply #2 on: January 30, 2015, 03:57:14 PM »
Just as a matter of experience I'd start with about 3/4" on the elevator horn.  5/8" bc to 3/4" flap horn is what I use with one to one flap/elevator and it seems a good start.  Your can then adjust either horn or handle line spacing to suit.
Offline Target
  • C/L Addict
« Reply #3 on: April 28, 2015, 05:37:29 PM »
I have Excel. Can you post a file here? Zipped maybe?
I'd like to have that.
Chris
Chris
AMA 5956
« Reply #4 on: April 28, 2015, 10:27:00 PM »
Email me and I'll send you the program.
Offline Target
  • C/L Addict
« Reply #5 on: April 29, 2015, 07:29:44 AM »
Your email is hidden, but I sent you mine in a pm. Thanks so much in advance.
Kind regards,
Chris Behm
Chris
AMA 5956
« Reply #6 on: April 29, 2015, 09:25:07 AM »
Sorry.  It's unhidden now.  I have nothing to hide.
Offline Target
  • C/L Addict
« Reply #7 on: April 29, 2015, 02:32:19 PM »
No worries, and thanks for the program. Appreciate your time, thanks. ;)
Chris
Chris
AMA 5956
« Reply #8 on: May 05, 2015, 09:03:36 AM »
Howard,
Is there a simple ratio calculation between the old 3" Veco bellcrank with the flap hole at ~5/8" the Veco flap horn connected to the BC at 5/8" and the flap to elevator at 1/2" if you use a 4" bellcrank? Wouldn't you just multiply all the hole distance dimensions by the 4/3 (1.33) to get the same leverage? Or if going from 4" BC numbers back to a 3" BC, take the 4" BC numbers and multiply them by 3/4 (0.75)?
Best,        DennisT
« Reply #9 on: May 05, 2015, 05:42:19 PM »
It's a 3-D problem, so other stuff is involved, but doing what you suggest would give pretty much the same relationship between bellcrank deflection and control surface deflection.  However, that's not what counts.  I'd define the leverage as the ratio of differential leadout travel to control surface deflection.  For your example, that would give the 3" bellcrank about 3/4 the leverage of the 4" bellcrank.
« Reply #10 on: May 05, 2015, 06:54:10 PM »
Isn't this over-complicating things for a sport model with (I'm pretty sure) no flaps?
I'd just aim for a reasonable amount of elevator deflection when the bellcrank is more or less fully deflected (60 degrees off center in each direction, more or less).
Then I'd finish the model and go have a ball.
« Reply #11 on: May 05, 2015, 07:03:30 PM »
That's what reply #1 said.
Reply #9 responds to Reply #$8.
Offline Phil Krankowski
« Reply #12 on: May 07, 2015, 07:30:23 AM »
Here's a similar question, asked in a different manner.  Some good replies on here.
http://stunthanger.com/smf/index.php/topic,38803.0.html
Phil
