  • July 17, 2025, 11:50:29 AM
Author Topic: Perky rules  (Read 1348 times)
Alan Hahn
Perky rules
« on: May 31, 2008, 09:53:29 AM »
Just a question about the rules we are using for the various Perky events, specifically line size, line type (stranded and solid) and pull test.
I know there may be more than a single set of rules, and I don't mind that, as long as I know which set I'm trying to fly to!
I was a little confused by the speed column in this months MA which gave a pull test of 25 grams! I assume it was meant to be 25"g's", but I have also seen in a post or two a 25 lb value (which would be 25g's for a 1 lb plane of course).
Thanks and I don't mean to set off any firestorms!
Offline Joey Mathison 9806
Re: Perky rules
« Reply #1 on: May 31, 2008, 04:37:59 PM »
try clspeed.com and click on perky rules
200 mph man ama#9806 joey mathison
Alan Hahn
Re: Perky rules
« Reply #2 on: May 31, 2008, 05:37:33 PM »
Thanks.
Alan Hahn
Re: Perky rules
« Reply #3 on: June 01, 2008, 03:06:52 PM »
For others, here is a link to the rules for the BlackHawk Postal Perky Contest Rules (I found Larry's thread below).
http://www.blackhawkmodels.com/perkycontest.html
The only difference (I noticed) between the BlackHawk and NASS rules is the Blackhawk specifies lines at 0.015, which I assume could be stranded. I can handle the difference. But I do need to finish my Perky. Just cleaned off the bench in the basement, so I'll be (re)starting tomorrow night!
« Last Edit: June 01, 2008, 06:35:38 PM by Alan Hahn »
