  • June 17, 2025, 10:42:40 AM
Author Topic: how to make piston/liner hones  (Read 2209 times)
Offline Lane Puckett
« on: April 05, 2012, 07:43:48 PM »
I recall there being an article in Model Aviation on how to make a piston and liner hone.
Does anyone know what issue that was in?
Also are there any other how to articles on making a piston and/or liner hone?
Thank you,
Lane
Re: how to make piston/liner hones
« Reply #1 on: April 05, 2012, 08:08:51 PM »
Not exactly what you're asking for, but this month's Model Engine News has a nice picture of some shop-made outside hones; if you go through the back issues and the engine build articles their's a wealth of information.
(And an engine that I rebuilt is in there, too, even if it's very much a beginner effort).
http://www.modelenginenews.org/
Offline qaz049
« Reply #2 on: April 08, 2012, 05:13:04 AM »
Thank you,
Lane
Lane,
you probably mean the Glen Lee article in the May 1996 issue of Model Aviation.
I have them scanned if you don't have the issue.
There are a few other articles on the topic perhaps the best is in the David Owen "Mate" diesel  build instructions on the MEN site.
regards Ray
« Reply #3 on: April 08, 2012, 08:19:50 AM »
Having lapped my first piston/cylinder combo for real just a month or two ago, all I can say is that once you have a feel for it the process itself is simple.
Be sure to use a fine enough abrasive -- the experts call out 800 or 1000 grit; pay attention.  I used Brasso (after screwing up a piston with 320 grit) because I'm a tightwad, and it works.  Too coarse a grit = too fast a cut, you can go from too tight to "oh @#$%" in one cut.
Even using Brasso (which cuts very slowly), I still made the fit a bit generous.  On the bench it felt really, really, tight.  I got impatient, cleaned things up, and tried it in the engine -- and in about half a dozen strokes it went to what felt like a nicely broken-in engine.  Given that the engine wasn't broken in yet, I suspect it'll have a short life.  (It runs fine now, but then it's only had about 10 minutes of running time).
Offline BillLee
« Reply #4 on: April 08, 2012, 09:12:46 AM »
What are folks doing that they need a piston or cylinder lap?
I can understand that if you're making new parts for old engines, or making new parts for a homebuilt or something. But if somebody is lapping the pinch out of a modern engine like a PA or a Jett or an OS or  ...,  I think you are fooling yourself into ruining a bunch of good equipment.
Bill Lee
AMA 20018
« Reply #5 on: April 08, 2012, 08:38:17 PM »
I can't speak for Lane -- I'm building engine parts from scratch.
« Reply #6 on: April 11, 2012, 07:31:39 AM »
Bill,
I picked up some one off oversize pistons and need to fit them.
Ray,
If you wouldn't mind emailing the scanned article I would be very appreciative.  As I recall there were two articles, one detailing the piston lap and one the cylinder lap but that is just from memory.
email is lkp1@yahoo.com
I'll go check out the other online reference you mentioned.  My search on that site before was very productive.  Quite a few very talented folks sharing their knowledge, it was interesting reading and I picked up some good ideas.
Lane
Offline qaz049
« Reply #7 on: April 13, 2012, 04:48:47 PM »
Bill,
Ray,
Lane
I've emailed the Article to Lane. The second page  should be attached below. The first is too large to attach so send me an email if you want a copy. They are a little indistinct in places I'm afraid but otherwise useful.
Ray
