  • July 17, 2025, 06:43:21 PM
Author Topic: how to measure wing area  (Read 3852 times)
Offline dssit
« on: November 30, 2006, 09:39:20 AM »
how do  you measure   both eliptical a nd stgardard wing area
Offline Scott Jenkins
Re: how to measure wing area
« Reply #1 on: November 30, 2006, 02:57:31 PM »
The area enclosed by an ellipse is πab, where 'a' and 'b' are the semimajor and semiminor axes and π is Archimedes's constant. In the case of a circle where a = b, the expression reduces to the familiar πa2.
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Offline dssit
« Reply #2 on: November 30, 2006, 06:17:10 PM »
scott. thanks for your reply. what I was trying to find out does thickness figure in  when your trying to come up with say 45 square inches on a standard wing.
