  • June 19, 2025, 11:30:56 AM
Author Topic: YAK 1 Photos  (Read 1433 times)
Offline t michael jennings
  • AMA 83322
YAK 1 Photos
« on: May 08, 2008, 08:07:12 AM »
Gentlemen,
Attached are photos of my latest Stand Off Scale model aircraft.  It is actually a Jim Silhavy "Magician" (published January 1951).
Below are particulars of the aircraft:
AIRCRAFT WEIGHTS:
     engine, muffler, & fuel system              13.0 oz
     wing & landing gear system                 15.7 oz
     fuselage                                            5.0 oz
     vertical stabilizer & rudder                    0.4 oz
     horizontal stabilizer & elevator               2.2 oz
     covering & paint                                 4.1 oz
     tip weight                                          0.7 oz
   TOTAL WEIGHT                                    41.1 oz
Engine:                                OS Max 35 S         (purchased in approx 1980)
Fuel Tank:                            Sullivan 4 oz slant  (used because on hand)
Notice the Stooge loop at the rear of the aircraft.
The front Control Line is UP.
I build in to the outboard wing tip 75% of the expected tip weight.
The CG (center of gravity) is .25 behind the design CG.
The aircraft is completely covered with Silkspan.
t michael jennings
knoxville, tn                                          y1
  • AMA 83322
Re: YAK 1 Photos
« Reply #1 on: May 08, 2008, 08:12:48 AM »
Gentlemen,
For some reason two of the photos were not attached.  Must be my computer skills.
Below is the second attempt to attach the photos.
t michael jennings
knoxville, tn
Re: YAK 1 Photos
« Reply #2 on: May 09, 2008, 09:00:03 AM »
That looks great.  Amazing what can be accomplished when we put our mind to it.  How does it fly?  DOC Holliday
Offline Mike Lauerman
Re: YAK 1 Photos
« Reply #3 on: July 25, 2008, 07:55:36 PM »
Wow, Mike Jennings has my hat and handlebar! Wife was flipping thru scale, and said "Wow, I thought that was you!"
  Lookin' good through these biased eyes, Mike! Like that Yak, too...
  • AMA 83322
Re: YAK 1 Photos
« Reply #4 on: July 25, 2008, 08:49:14 PM »
Mike,
Thanks for the compliment.
For more see:
"P-51C Excalibur" on Stunt Hanger
"P-51D, Ole Yeller" on Stuka Stunt
"Heinkel He-100" on Stuka Stunt.
t michael jennings
knoxville, tn
Offline Just One-eye
  • Another Old Fart
Re: YAK 1 Photos
« Reply #5 on: July 26, 2008, 02:33:14 AM »
"Attached are photos of my latest Stand Off Scale model aircraft.  It is actually a Jim Silhavy "Magician" (published January 1951)."
I believe you are 8-10 years off of the date.  No, not back to 1941, because that would've been before Jim was born, or when he was still just a toddler.  The first Magician was built about 1958 or 1959.
 ;D
