  • June 19, 2025, 02:00:44 PM
Author Topic: Paint question F2A Brewster Buffalo  (Read 2212 times)
Offline Allen Goff
  • Charter Member
    • Fellowship of Christan modelers
« on: December 16, 2011, 11:51:20 AM »
  D>K  The F2A Brewster is out of the paint booth. (primer) I will start wet sanding tomorrow.
Help on this part of the painting process.
On the clear coat I plan to use the two part automotive clear,(can't use dope because I use 15% nitro) but it needs to be a flat not a gloss coat. All you paint experts out there, I need your help on this one. HOW TO MAKE IT FLAT.
Blessings
Allen
Offline Michael Boucher
Re: Paint question F2A Brewster Buffalo
« Reply #1 on: December 16, 2011, 12:46:25 PM »
Mix in corn starch? Has anyone else heard of doing this? I thought I had read this at some point.
AMA 59633
« Reply #2 on: December 16, 2011, 01:19:07 PM »
Michael,
It's Oatmeal, not corn starch.  ;D
CB
« Reply #3 on: December 16, 2011, 01:26:01 PM »
On the clear coat I plan to use the two part automotive clear,(can't use dope because I use 15% nitro) but it needs to be a flat not a gloss coat. All you paint experts out there, I need your help on this one. HOW TO MAKE IT FLAT.BlessingsAllen
Allen,
I've never sprayed a clear coat with a look of "flat."
Being a Warbird, I would shoot the clear then use steel wool on it. Mask off and make panels. Etch in different directions?
You can purchase a "flattening agent" that is mixed with paint.
You could bring a jar to a body Shop and ask for an ounce. You'll only need a few drops.
You could use automotive "color" paints that are one stage.
CB
Offline chuck snyder
« Reply #4 on: December 16, 2011, 03:20:17 PM »
I'm pretty sure Klass Kote sells flattening agent. I'm guessing it is barium sulfate. You might also check with your auto paint supplier.
Chuck
« Reply #5 on: December 16, 2011, 06:32:37 PM »
I dont know about other brands, but PPG uses a product called IIRC Flexed and flat. Its a clear product that you add to your un-catalized clear before you mix it. Something on the ratio of equal parts clear and Flattening agent. They also sell a premixed flattening clear that you catalyze and spray however that does not allow you to adjust the ratio of how flat , semigloss, or satin you want the finished product.
I would NOT recommend randomly mixing anything with a urethane clear.
« Reply #6 on: December 16, 2011, 10:44:12 PM »
 Flat and/or satin finishes are very popular in the Hot Rod world these days, have been for a while now. I think most of the quality paint jobs are actually done using regular paint and then they get finished with a satin clearcoat. With that in mind, I'd have to assume that any knowledgeable automotive paint supplier should be able to set you up with compatible products for you to do a flat finish.
 ...don't forget to tell them that your camouflage painting your Buffalo and see what kind of look you get. ;D
« Reply #7 on: December 16, 2011, 11:19:40 PM »
wait for it, waaaiiittt for it,,
yeah it took me a minute then I got this flash picture in my head of a buffalo standing in a field in camo colors LOL,,
hey I may be dumb, but at least I am slow,,  HB~>
« Reply #8 on: December 17, 2011, 09:59:14 AM »
Can you imagine the look on the clerks face at the auto paint  store if he says that. LL~ LL~ LL~
I am dense and had to read it a couple of times.jeh
Offline Allen Goff
  • Charter Member
« Reply #9 on: December 19, 2011, 08:37:56 AM »
  D>K  I called my local paint store and he informed me that PPG makes a flattner,"a universal mating agent".
The clear will mix; 4 parts clear. 1 part activator. 1 part flattner.
Thanks for your help guys, and the joke too. LL~
Blessings
Allen
Offline Wayne J. Buran
« Reply #10 on: December 29, 2011, 08:20:21 PM »
Brodak stocks a Randolph flattener BP-1092P (pint). $17.99 plus shipping. I also have stock.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Online bill bischoff
« Reply #11 on: December 30, 2011, 04:37:05 PM »
The reason that is so hard to flatten a buffalo is because they are so big. A regular passenger car won't do it. You need a really big truck, or possibly a freight train, in order to flatten a buffalo.
Offline Allen Goff
  • Charter Member
« Reply #12 on: December 31, 2011, 07:03:16 AM »
Thanks Wayne
Blessings
Allen
« Reply #13 on: December 31, 2011, 03:31:35 PM »
Anyone notice the dog peeking over the cab of the first truck in Bill's picture?  He's thinking of chewing on a steak, the heck with flattening it! LL~ LL~ LL~
« Reply #14 on: January 02, 2012, 05:29:47 PM »
LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ H^^
