  • July 05, 2025, 09:16:33 AM
Author Topic: B-17 project  (Read 1804 times)
Offline Allan Perret
  • Proverbs
B-17 project
« on: June 20, 2009, 06:49:10 AM »
Wanting to build a B-17 using 2 Norvell 61's in the 2 & 3 positions,
with the 1 & 4 positons being dummy engines with free wheeling props.
Question is how big to make it.  I have the Guillows 2002 kit which is a 1/28 scale with a span of 45".  But I feel like the two Norvell's would handle a larger plane, maybe around 52~54" span.   Comments or suggestions ??
Anybody know of any plans available for a 54' span B-17.
My dad was a B-17 bombardier, he flew 33 combat missions.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
Re: B-17 project
« Reply #1 on: June 20, 2009, 02:35:20 PM »
here is a C/L from a model mag for 4 .05s
B-17G Flying Fort   1963 AM Jl-Ag p16   span 44.50 area 270.00 power .05 x4 plan 763 Laumer, Keith & Simmance, John
there is an 80" R/C model for .20 x 4 engines
contact me direct for the scans = tawilk36@cpinternet.com
Tom Wilk
Offline Mike Keville
Re: B-17 project
« Reply #2 on: June 22, 2009, 08:54:14 PM »
Once you get the scale sorted-out, go ahead and build it ----- and bring it to the Tucson Cholla Choppers annual 1/2A multi-engine PROFILE scale contest, October 11-12.
Details and rules available:  vsc-guy(at)cox(dot)net.
Re: B-17 project
« Reply #3 on: June 26, 2009, 12:02:26 AM »
 Crossing one of these modern F2D combat wings , and a profile scale B-17 is a thought thats been annoying me for years !
                                                (structurally )
All those propellors should be fairly usefull if streamers are involved somewhere !
Re: B-17 project
« Reply #4 on: July 27, 2009, 06:52:26 PM »
Tom Wilk
Hi Thomas,
I bought that issue of American Modeler back in 1963 just because it had the B-17s on the cover! LOL!!  I waited almost 40 years to get a set of those plans.  The model won the British NATS in 1963.  It had a lot of *homemade* optional features.  It used homemade exhaust *throttles* on 4 Cox .049s.  The LG retracted through an electrical switch which was wired through the engine throttle control.  A Pittman electric motor (which doubled as nose weight) was used to drive the gears for the retracts.  It all worked together through a disc, which had copper relays on it, connected to the throttle wire.  It also gives the option for fixed gear and two engines, if I remember correctly.  I would have to get the plans, and magazine, back out to check it all again.
It is one scale model I have wanted to build ever since 1963......
Bill Little
